Old 04-21-2011, 11:42 PM
mamw mamw is offline
Vehicle: 2009 Ram 1500 slt 2wd
Trim Level: ?
mamw is on a distinguished road
Default Towing capacity
I have a 2009 Dodge Ram 1500 with a 321 gear ration that when we pull our camper that weighs 4000lbs the engine light comes on, the company states it can pull 5500, and that nothing is wrong with the truck. Anyone got any suggestions??? We need help!!!
Old 04-22-2011, 12:02 AM
Rep:2640
the chart that i looked at reads around 5,000 pounds too
go to
http://www.dodge.com/bodybuilder/2009/intro.pdf
click RAM
http://www.dodge.com/bodybuilder/2009/dr/drmo.pdf
choose cab
then continue with the prompts
base weights, payload, trailer tow
Old 04-22-2011, 12:37 AM
Trim Level: ?
We have had it to the dealership twice, had it weighed loaded as coming in under 4000lbs, we have loved our truck but now we are not sure what to do. Thought about upgrading the gears but we are hearing we may loose our warranty.
Thought about decreasing our tires to 17 inch but that will also cost about 2000.00..
Just unsure about what to do. Everyone is blown away that our truck can't tow it, but no one can give us an answer on how to fix it..
Old 04-22-2011, 02:57 AM
Rep:2640
You could go to a lower gear, if you tow often you will loose some MPG
BUT, you could go with the 3.55 or 3.90 ring & pinion from Yukon for something like $360 & labor
new parts would be warrantied through either a ASE certified garage or your Dodge dealership, if they will install it. Then you could sell the parts that are in it now & get some of your money back
or through Mopar
Ring and pinion, ram 1500, 3.92 ratio - CHRYSLER
09-10 $626.78 & labor
but, if it is a software issue & it still gives you that message ......... ?
Old 04-22-2011, 11:28 AM
DBryant DBryant is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT, Big Horn
Color: Crimson Red
DBryant is on a distinguished road
What engine light was on? The light would not come simply because you towed more weight than the truck is rated for. It doesn't know how much you are towing. You have another problem that is causing the light to come on.
Old 04-22-2011, 11:55 AM
LUBINATOR's Avatar
LUBINATOR LUBINATOR is offline
Richie
Vehicle: 2009 Ram 1500 SLT Quad Cab
Color: Inferno Red
Rep:12
LUBINATOR is on a distinguished road
Default good point
Good Point, have the dealer run the diag code and see what has happenned. If you are on the road and it happens, pull into a dealer and let them plug the truck into their computer.
RAM 1500 SLT QC 2009 INFERNO RED, ARE Lift Lid ,Spray on Bed Liner, K&N Drop In, Pioneer DEH P8400UB, Alpine Amp, Mopar Kicker sets in all doors and dash, 2 Polk 10" Subs, Polk AMP, SteelCraft Nerf Bars, Mopar Fog Lights, CalTrend Seat Covers, WeatherTech Front Mats, Putco SS Fender Liners, SuperBumper SS Hitch Step/Impact Absorber, Onki Aegis SS Center Guard, PIAA 2100 driving lights
Old 04-22-2011, 04:04 PM
CORUPTWJ's Avatar
CORUPTWJ CORUPTWJ is offline
Vehicle: 2009 Dodge Ram
Trim Level: St
Rep:37
CORUPTWJ is on a distinguished road
Agree with the 2 above. Get it to the dealership and have them check the codes if you are getting an engine light when towing. My guess is the extra weight and strain on the engine is causing the issue. You sould have no problems at all towing 4000lbs with a Ram. You should be able to pass people left and right even with towing that little bit of weight.
Old 04-22-2011, 05:35 PM
pjs1660's Avatar
pjs1660 pjs1660 is offline
Vehicle: 2011 ram 1500 outdoorsman
Trim Level: slt outdoorsman
Color: green
Rep:137
pjs1660 will become famous soon enoughpjs1660 will become famous soon enough
how soon after you start towing does the light come on ? could the engine or trans temp be getting too high?
Old 04-23-2011, 09:48 AM
Trim Level: ?
Talked to our service guys yesterday and he seems to think the same that the engine light is coming on because the transmission is not performing to what it is suppose to be. The code we had stated that is was overloaded and that the transmission was slipping. So we are going to take our camper out again and see how fast the light comes on. It usually comes on as soon as we pick up speed to 60ish and the tow/haul is engaged, Both times we used it it came on within minutes of getting on the highway..
Old 04-24-2011, 03:14 AM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
Tow rating assumes roughly the same 36.6' Frontal Area as the truck. If your trailer has more frontal area it will reduce the trucks ability.
Assuming nothing is wrong with the truck try placing it in "ERS 4" when towing which will lock out the two overdrives and place you around 2000 rpm @ 60 mph. I think the transmission is slipping in overdrive because of a combination of high frontal area (80'-100'?), tall tires (33") and tall gears (3.21).
If you decide to make changes to the truck I would suggest 3.92 Gears and keeping current tires. Changing tires would only change effective gear from 3.21 to 3.34 and at worst you would only lose warranty on the rear differential not the whole truck. Just have the dealer reflash the PCM for the sales code for the 3.92 Gear to keep speedo, transmission, odometer and ABS functioning correctly.
Gene
Help! Towing capacity 2010 Ram 1500. westxsrt10 Towing 21 10-18-2011 12:37 AM
towing capacity??? bluefever Towing 3 02-09-2011 10:06 PM
Towing Capacity barrelracer Towing 1 08-28-2010 01:24 AM
2500 Ram 5.9 Diesel Towing Capacity Captain Ron Towing 3 03-23-2010 12:13 PM
Towing Capacity Joe Rotax Towing 4 06-03-2009 10:10 PM
