Old 04-22-2011, 03:33 PM
belle belle is offline
Vehicle: 2011 Dodge Ram Laramie
Trim Level: laramie
Color: rugged brown two tone
belle is on a distinguished road
Default Tire PSI question
I installed a 2.5 inch level kit.. took off the 275/60/20 stock Goodyears.. put on 275/65/20 Dynapros, Stock tire PSI on the door is 35. What does this new setup require? I figured about 40. What do you guys think?
Old 04-22-2011, 05:49 PM
williamhartle's Avatar
williamhartle williamhartle is offline
Vehicle: 2007 dodge ram
Trim Level: st
williamhartle is on a distinguished road
ive got 285 79 17 on mine i run 40 in the front and 35 in the rear unless im towing then i up both by about 5 psi. i get a nice even wear
2 inch leveling lift 3 inch body lift, 34" bfg mud terrain TA KM2, straight pipe, vararam intake, superchips cortex, Firestone air bags, skyjacker n8000 shocks rear, s8000 front struts, painted head lights, tinted tail,cab mount light, big shiny chrome balls.
Old 04-25-2011, 11:19 AM
Trim Level: laramie
I've found 40 psi feels good for this set up. thanks,
Old 04-25-2011, 11:56 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
PSI = PSI and is not related to the tire size. PSI is measured as pounds per square inch. So the guage will read the feedback of a small area vs a large area as the same measurement. It just take more air in a larger tire to get the same readout. The MAX INFLATION printed on the sidewall is the MAX pressure you should run at. If it says 40, then you can run up to 40. The lower the pressure, the more flex in the sidewall and therefore the more comfortable ride...the more the pressure, the stiffer the sidewall and the more bouncy the ride. Just don't go too low as to cause a pressure light, or actual tire damage. I would guess between 35 and 40 should be fine.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
24" tire question Lakelandhuskers Dodge Ram Wheels And Tires 3 02-02-2011 12:45 AM
Newbie with tire question calbear Dodge Ram Wheels And Tires 8 01-15-2011 02:03 AM
Tire Pressure Sensor Question AKRAM Dodge Ram Wheels And Tires 3 11-21-2010 09:46 PM
Tire Question... rob Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 12-12-2009 10:53 PM
Low tire pressure indicator question imnxnyr Dodge Ram General Discussion 14 10-06-2009 11:49 PM
