View Poll Results: Where should I dump the exhaust?
Straight out the back 21 60.00%
Angled behind the rear tires 8 22.86%
In front of the rear tires 6 17.14%
Voters: 35. You may not vote on this poll
Old 04-22-2011, 05:05 PM
jgshannon jgshannon is offline
Vehicle: 2005 Dodge Ram 1500
jgshannon is on a distinguished road
Default Magnaflow Exhaust
I'm thinking about going in and getting dual exhaust put on my truck and I was just curious about your thoughts on a 14" or 18" Magnaflow and where I should dump it at. Thanks guys.
Old 04-22-2011, 06:30 PM
chefred112's Avatar
Rep:656
18" dumped just over axle...before axle will be loud in cab, piping to rear or stock exit will drone in cab...I'm running a 22" mag dumped over axle and it is quiet in the cab..
-fast freddie- one quick 05 hemi qc...with over 275k miles on odo... on the 5.7, stoker 6.4 now...Inertia Motorsports 392 stroker
Old 04-22-2011, 06:50 PM
mbehlok's Avatar
mbehlok mbehlok is offline
Vehicle: 2014 Dodge Ram Laramie 4X4
Trim Level: laramie
Rep:39
mbehlok is on a distinguished road
I have the 14" Magnaflow SI/DO and they go straight out the back. I do not get much of the drone and the cab is pretty quiet once up to speed. When I gun it, i can definitely hear it..
I also disabled MDS, so that may be one of the reasons the drone is not as bad..
Stock for now!
Old 04-23-2011, 12:50 AM
StoneyWV StoneyWV is offline
Vehicle: 2010 Ram Quad Cab 4X4
Rep:27
StoneyWV is on a distinguished road
Confused; how does dumping over axle make the system quiet when factory exit out the side drones? With my stereo background it sure seems as though the exit under the bed where the sound is bouncing off of things would be louder than the factory exit out the side where the wind catches all the sound waves.
I just got the 14 put on with factory resonator still on the system and it drones pretty bad. Almost annoying with MDS kicked in. With MDS off, it sound great and I don't mind the volume level at all. It even sounds a little muffled to me.
Who has removed resonators and found the droning to stop? I"m concerned that the drone will get louder and that would be cause to reverse everything for me.
Just trying to not re-invent the wheel on this process, as I"m sure most people do.
2010 QC ST, 5.7L, 4.10 Gear Swap, 5100 Leveling Shocks at 1.7", K&N Drop-in, Pioneer U310BT, 12" Dayton/Net Audio Sub, JL Components, ARC Audio Amps, Magnaflow 14 inch, Granite Alloys sporting 34" BFG T/A KO, HID conversion full blackout.
Old 04-23-2011, 01:12 AM
mbehlok's Avatar
Trim Level: laramie
Rep:39
I left the front Resonator in place, took out the Muffler and the resonator at the rear near the tail pipe.
I do not get the drone too bad at all. My tail pipes exit straight out the back.
I also have the 14" Magna..
Stock for now!
Old 04-24-2011, 01:03 AM
08murderedram 08murderedram is offline
08murderedram is on a distinguished road
i had the same dilemma. I had a 18 inch for the past few months and couldnt hear it inside but i wanted a little more out of it so i went w the 14 si/do and i couldnt be happier, its the same great tone but louder when you get on it for sure and barely noticeable inside. id go w the 14 100%
Old 04-24-2011, 04:49 PM
Angle them or dump them right behind the diff & axle tubes.
Old 06-03-2011, 02:30 PM
wannab's Avatar
wannab wannab is offline
Vehicle: 2011 Hemi sport
Trim Level: Sport QC.
wannab is on a distinguished road
magnaflow mid pipe back exhaust, 22 inch muffler 2.5 inch tails no resonators, and great tips. absolutely no drone at all. sounds great. 520 shipped. I installed mine in an hour in my driveway. Sounds a lot louder than just a 22 inch muffler alone.
2011 Black Sport Quad cab Ram, Magnaflow midpipe back exhaust, K+N intake.
Old 06-10-2011, 03:57 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
If you haven't decided yet....
Take this into consideration. If you think you will ever hook up a trailer, you will HATE having the exhaust straight out the back. Nothing like hot CO blowing in your face while you are hooking up the trailer. That is one reason I love my exhaust dumping out the side. Duals look cool, but lack in practicality for me.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 06-11-2011, 12:48 PM
bombadillo's Avatar
bombadillo bombadillo is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Rep:25
bombadillo is on a distinguished road
I ran dumps on a car of mine and I got some fumes in the cab till I sealed her all off. I would go behind the tire and kind of high mount it if you can so if you off-road with it you won't catch it coming off of something. It will keep a stock look if you ever sell it and won't limit your market. As to magnaflow, BIG A+++++ on their 14" straight through. I left my stock resonator on it, and ran magnaflow and it sounds so smooth. At idle you wouldn't know I even had an aftermarket setup on it and in overdrive it sounds like a factory truck, but when I really get on it, its nice and smooth with a super throaty sound. I really like it a lot better than the flowmasters I was considering.
Edit: And I had a buddy install my muffler and tip for me for $140 paying cash
2011 4.7L with AVS ventshades, Vision 375 Warrior wheels, Daystar 2.5" leveling kit, GTS Blackout taillights. Magnaflow exhaust done custom, (sounds AWESOME) and I'm sure more to come.
Magnaflow 18" Exhaust installed with my feedback Ray 2010 Dodge Ram Forum 33 04-07-2011 05:56 PM
Magnaflow or Gibson exhaust 2000RAM Exhaust 3 02-23-2011 08:03 PM
2010 Magnaflow Exhaust Options markpsu 2010 Dodge Ram Forum 9 08-18-2010 08:34 PM
5.9L Cummins Magnaflow 5" Axle-Back Exhaust with 6" S/S Tip Justin@AACstyle.com Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 0 06-16-2010 03:11 PM
Magnaflow 5" Exhaust with 6" S/S Tip for 04.5-07 5.9 Cummins Justin@AACstyle.com Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 1 02-17-2010 01:52 PM
