tonneaucovered.com
Old 04-22-2011, 07:07 PM
beave928 beave928 is offline
Vehicle: 1999 dodge ram 2500
Color: whitw
beave928 is on a distinguished road
Default changing rear axel seal need help plz!
My truck is torn apart and I nee help pulling my hub. It has an axel nut I need to take off but do not know the size of socket I need. Its a spicer 6200 rear axle which I'm pretty sure is a dana 60. My truck is the 99. Ram 2500 360ci w factory 4.10 gears: ) which I was stoked to find out but this is a cry foe help I have put this of for 8 months or more so now I'm buckling down.
Old 04-22-2011, 07:12 PM
Color: whitw
Default replacing rear axel seal need help
Hello my truck is torn apart an I can't find what size my axel nut is to remove the hub.my truck is a 99 ram 2500 360ci rear axel is a spicer 6200 which I'm sure is equivelent to a dana 60 w factory 4.10 gears. Is there anything else I will need as far as speicific tools goes I genuinly appreciate the help boys
Old 04-22-2011, 08:37 PM
Color: whitw
Default rear axle seal need help
I'm trying to find out what size of an axle nut socket I need I can't find it anywhere on thw internet. My truck is a 99 ram 2500 w spicer 6200 rear axle
Old 04-22-2011, 08:57 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Wish I could help. Have you tried posting in the help section?
http://www.ramforumz.com/forumdisplay.php?f=181
Old 04-22-2011, 09:14 PM
RedRam10's Avatar
Rep:743
http://www.ramforumz.com/forumdisplay.php?f=170
try posting here - look for the area that meets your specific needs. The tech's live in these areas
Old 04-22-2011, 09:15 PM
RedRam10's Avatar
Rep:743
Old 04-22-2011, 09:44 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
It's 2-9/16". Miller # DD-1241-JD
brad
Interested in one of my mods?
Old 04-22-2011, 10:07 PM
Color: whitw
Yessir I did post there thank you very much. A member named brad said it was2 9/16 which sounds realistic but our local parts store doesn't carry nor will they order it. So.I'm hoping it might be the 1 3/4 that another website posted but man idk
Old 04-23-2011, 04:48 PM
Trim Level: sport
Color: green
Rep:682
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
you went to a parts store and tried to order a part and they refused? whats up with that?
Old 04-23-2011, 06:45 PM
Rep:2731
Dodge Ram 19942002 (BR/BE)
Axles
The Dodge Ram featured a wide variety of axles. For the front axle of 4x4 Rams, a Dana 44 was used on all 1500 Rams and some, early, light duty 2500 Rams. However, most of the 2500 and all 3500 Rams used Dana 60 front axles.
The 1500 Rams and some early light duty 2500 Rams used a 9.25 Chrysler axle in the rear. A Dana 60 rear axle was used on heavy duty 2500 V8 Rams. A Dana 70 rear axle was used in 2500 Rams with a V10 or a Diesel/Automatic transmission combination.
A Dana 80 rear axle was used on 2500 Rams with a manual transmission and diesel engine combination and all 3500 Rams.
The front solid axles in these rams were unique in the fact they didn't feature Locking hubs, but featured a Center axle disconnect. The 2002 2500 and 3500 Rams saw the eventual phase out of the Center axle disconnect, in favor of front axles that were permanently locked in. Dodge continues to feature front axles like this for their 2500, 3500, 4500, and 5500 trucks.
DANA/Spicer 60 front axle full info
http://www.pirate4x4.com/tech/billavista/60_front/
i did find this on a forum for off roaders
I have a Dana 60 rear end, & took off the drum to check the brake-shoe linings. In doing so, I discovered that there is only ONE nut (hexagonal 2 9/16", not a "6 notch" nut) keeping the outer-bearing in place! (there is a small wedge, which friction fits into the key-way, to prevent the nut from loosening).
According to the manuals I've read, there is an inner
adjusting-nut, lock-ring, lock-nut. You torque the adjusting-nut to 50 ft-lb while rotating drum, back off the adjusting-nut 60 to 90 deg or so (so that the lock-ring will "mate" in alignment hole), & then tighten the lock-nut to xx ft-lbs (one manual states 65 ft-lbs, but that is for a 1 ton Dana 60 front axle. I never got a figure for a Dana 60 rearend locknut).
Since I only have 1 nut to work with, how should I install it? What I did was, tighten it to 50 ft-lbs, but I didn't back it off any. Then, I just put in the wedge in the keyway, to keep the nut in place.
Is the above OK, I'm concerned I don't have the locknut too tight to damage the outer-bearing.
I'm also worried that if this wedge ever came loose, the nut would come loose, then the tire/drum/axle could conceivably come loose during driving. There's about 1/4" left of threads on the axle-housing, so I think I could go & buy an additional adjusting nut & lock-ring.
Question: Have any Dana 60's come equipped like mine, which have only 1 nut? This doesn't sound right, it needs the redundancy of the adjusting-nut, lock-ring, lock-nut.
answer was
howdy / thats the way newer dana 60,s are / that nut with the little lock is all you need / I never had one fall out / the only way it can is if the lock nut wears out from taking it apart to many times / if you set the pre-load right and the lock gets a good bite in the nut your all set / PRE-LOAD / snug it down tight and then back it off a little till you get a tiny bit of free play / doing wheel bearings is an art form to get it right / not to tight not to loose / good luck
spicer 60 front and rear axel question pirayaman 5.9L V8 Specific Topics 1 03-11-2012 11:34 PM
Rear Pinion Seal shocker 5.7L V8 Specific Topics 1 04-15-2011 07:58 AM
Rear Axel Fluid Recall 2011 Dodge Ram 1500 E220 Dodge Ram Recalls and TSB's. 27 03-14-2011 10:51 PM
needing tips on changing rear main bearing calob98ram 5.2L V8 Specific Topics 0 04-27-2010 11:30 PM
93 cummins rear main seal is leaking rfishman47 Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel 2 11-19-2009 07:40 PM
