MOPAR DECALS
Old 04-23-2011, 11:24 PM
beave928 beave928 is offline
Vehicle: 1999 dodge ram 2500
Color: whitw
beave928 is on a distinguished road
Thank you for your time Guys! Greatly appreciated. For future ref. My truck is a 99 2500 w dana 60 rear (aka-spicer 6200) the axel nut socket is a 2 9/16" I was concerned but when I backed the nut off a metal clip in a groove curled the seal on axle nut but it coiled very neatly in this gap like that was Intend? Is anyone familiar with This?I used thread locker when re-installing but semi-worried about improper Installation?
Old 04-24-2011, 12:11 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Yes. That is the locking tab. Your actually supposed to bend this back before removing the nut....Opps! It's basically a thin metal washer with tabs that can be bent to lock the nut from turning after it's installed. Usually there are more than one tab, so if one is broken off, you can use on of the other ones. Only 1 locking tab is required.
BTW - Here is a link to the Dana60 service manual. Page 32 covers the locking tab.
brad
Interested in one of my mods?
Old 04-25-2011, 12:02 AM
brad12kx's Avatar
Rep:2581
Just checking....how are you making out with this?
brad
Old 04-25-2011, 10:06 AM
Color: whitw
Good i got it reassmbled but I havnt drivin it Yet? Like I saod I curled off that plastic seal that was on the nut. I'm thinking that was there to stop gear oil from getting in the threads and breaking it loose also when I backed it off that metal retainer clip came off so that's not in place at the moment either. I was smart enough to use a good bit of thread locker when I re instaled the nut but I'm srill worried.
Old 04-25-2011, 10:41 AM
brad12kx's Avatar
Rep:2581
The plastic seal is actually not a seal. It is what is called a 'Ny-lock'. It is intended to stop the nut from loosening easily. The metal locking tab, however, is VERY important. The last thing you want is to have that nut back off under normal driving conditions. As this nut is there to hold the bearing in place, it is not 'tightened' per say, so you can't rely on thread torque to hold it.
I'm not sure, but would expect that you can buy the metal locking washer thingy as an individual part from the dealer or an auto supply store. It would be worth checking into.
brad
Old 05-04-2011, 04:13 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
You seem to know your stuff BRAD12kx. Nice
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
spicer 60 front and rear axel question pirayaman 5.9L V8 Specific Topics 1 03-11-2012 11:34 PM
Rear Pinion Seal shocker 5.7L V8 Specific Topics 1 04-15-2011 07:58 AM
Rear Axel Fluid Recall 2011 Dodge Ram 1500 E220 Dodge Ram Recalls and TSB's. 27 03-14-2011 10:51 PM
needing tips on changing rear main bearing calob98ram 5.2L V8 Specific Topics 0 04-27-2010 11:30 PM
93 cummins rear main seal is leaking rfishman47 Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel 2 11-19-2009 07:40 PM
