Old 04-23-2011, 08:45 PM
asmith352's Avatar
asmith352 asmith352 is offline
Vehicle: Dodge Ram 1500 V6 Regular Cab
asmith352 is on a distinguished road
Default 2003 dodge ram 1500 a/c blows cold only when moving
I have an 03 dodge RAM 1500 manual shift reg cab with 120k miles. It blows cold air only when moving. If I'm stuck in traffic or at a light it still blows air but its just not cold like when shes moving. Any suggestions as to what may be the problem?
Thanks in advance.
2003 Dodge Ram 1500
Old 04-24-2011, 05:06 PM
Are you seeing an increase in engine temp when stuck in traffic? If so, how much? Does the air get hot or just warm up a bit?
The A/C system will be affected by airflow across the condenser, engine temp and ambient conditions.
Old 04-24-2011, 05:19 PM
RansRAM's Avatar
RansRAM RansRAM is online now
Addicted to the Z
Color: PX8 Black
Rep:2471
Make sure that the condensor fan is working whenever the A/C clutch is engaged. The A/C system needs a constant airflow across the condensor, which is pretty much garanteed when you are moving.
Old 04-24-2011, 05:20 PM
^^^^ Good suggestion! ^^^^
Old 04-25-2011, 01:27 AM
dksram's Avatar
dksram dksram is offline
Vehicle: 2007 Dodge Ram 1500 Quad Cab
Rep:27
dksram is on a distinguished road
I agree with ransram
I would park it somewhere safe and leave it in neutral with the brake on. Open the hood and look at the fan on the condensor. It's probably sticking which will soon burn out like mine did. You can get the motor, fan and shroud on ebay for 70.00 or less.
http://cgi.ebay.com/ebaymotors/ws/eB...24969&viewitem=
Will Dodge Ram 1500 2010 Wheels and Tires fit a 1998 Dodge Ram 1500? koalatyman Dodge Ram Wheels And Tires 1 04-14-2011 10:38 PM
Dodge 1500 in NM rodanst6 Newbie Checkin! 13 03-23-2011 04:31 PM
What year of factory wheels will fit my 2003 Dodge 1500 quadcab? Dhunter Dodge Ram Wheels And Tires 3 04-26-2010 01:08 AM
getting rid of my 1996 Dodge Ram 1500 johnnie_5 Newbie Checkin! 7 08-19-2008 04:37 PM
