Old 04-23-2011, 09:32 PM
jeffp1970 jeffp1970 is offline
Vehicle: 2000
jeffp1970 is on a distinguished road
Default Steering wheel upside down
I purchased a 2000 dodge Ram 1500 4x4 and the steering wheel is upside down. It has a 3" lift. Can I adjust the drag link to recenter the steering wheel, or do I need to drop the pitman arm and recenter?
Old 04-23-2011, 09:43 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
sounds like it needs just a good alignment. Was the lift installed recently? It could have thrown things out of whack and given some positive camber as well. I would take it to a shop to have it done but, have somebody hold the steering wheel in place where it SHOULD be and then adjust the lock nut on the tie rods. thats how it is on my truck but it's a 1998, im not sure how the setup looks on newer 2nd gens. I don't think it will be too easy, Usually we have plates under each wheel that slide and pivot effortlessly to let the wheels toe in and out.
Old 04-23-2011, 10:19 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
A big Hello and a Warm Carolina WELCOME! I hope you make the most of the best RAM ForumZ on the Web! Drop in at the Newbie Checkin, use the link in my SIG. As for the steering wheel issue I agree with "98SST" .
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Center Your Steering Wheel - R&P Steering RamTech Dodge Ram Knowledge Base 5 02-28-2015 06:39 AM
steering wheel has slight cockeye after 3in BL Inferno Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 02-04-2011 03:13 PM
changing clockspring awful knawful Body & Interior 2 05-08-2010 05:27 PM
Steering wheel wobble Mayhem4216 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 1 04-08-2010 04:50 PM
