Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V6 Specific Topics
Old 04-24-2011, 01:41 AM
JACKED UP DODGE's Avatar
JACKED UP DODGE JACKED UP DODGE is offline
JACKED UP DODGE is on a distinguished road
Default 2000 V6 3.9Liter 2WD bogging down at idle and while running any help please?
hi I have a 2000 dodge ram 3.9 Liter 5speed 2wd and it Boggs down at idle and when driving between 1st and 3rd gear at about 1000-2000 rpms it sometimes wont do it when it does it will back fire through the throttle body and act like its going to die then i can give it a little gas and the rpms will shoot back up..and when it doesent do it it seems like i dont have any power then i will get 2 about 2200 rps it will get all its power...but it does it at random times but it has been doing it alot lately it actually backfired through my exaust and split the muffler in half at the seem I had 2 get it relaced..i have pulled it in to my high school auto mechanics class multiple times and have hooked it up 2 the computer and the only codes that are comming up are the o2 sensor codes and i already replaced them i also did an injector test and the injectors are fine..well here are all the things I have replaced distributor cap and rotor,spark plug wires,up stream and down stream oxygen sensors,exaust,water pump,and flushed raidator..any help would be gladly apprechiated..please help asap this thing is pissing me off..!!...thanks..
2000Ram 2"RoughCountry lift&1.5ProComp block,ProComp&SkyJacker shocks,K&N Intake,285/75/16 ProComps
Old 04-26-2011, 04:58 PM
Default Please!!Please!!
Any help please im getting ready to take a sledge hammer to this truck..please help me asap!!please!!
Old 05-08-2011, 10:58 PM
Stevo's Avatar
Stevo Stevo is offline
Vehicle: 2000 Dodge Ram 1500
Color: Green
Rep:13
Stevo is on a distinguished road
What all has been replaced or worked on?
Old 05-18-2011, 10:33 PM
I have replaced distributor cap and rotor,spark plug wires,up stream and down stream oxygen sensors,exaust,water pump,and flushed raidator..any help would be gladly apprechiated..thanks.
Old 05-18-2011, 10:44 PM
frealz13's Avatar
frealz13 frealz13 is offline
Vehicle: 2001 ram 1500 4x4
Trim Level: slt laramie
Color: blue silver
frealz13 is on a distinguished road
did you cross the wires
-PAT-
Old 05-29-2011, 03:49 AM
No the wires are fine..Im not sure whats wrong with this truck its weird its running fine now?I have no idea what to do with this truck anyone know whats wrong with it?
Old 09-25-2011, 11:39 AM
Wayland Wayland is offline
Vehicle: 2005 Ram 2500 Diesel Quadcab
Color: Maroon
Wayland is on a distinguished road
If it is heating up when this happens maybe a partially plugged converter or some kind of exhaust restriction.
Old 09-25-2011, 11:45 AM
Color: Maroon
The high school thing makes me think? Is there a shop rag or something else shoved in your tailpipe?
Old 09-25-2011, 02:18 PM
BigGreen13's Avatar
BigGreen13 BigGreen13 is offline
Vehicle: 2001 Dodge Ram 1500
BigGreen13 is on a distinguished road
Bad cat? that what it was in my 99 ram 1500 and sounds like the same problem, I just cut it off lol
~HellBoy~
Old 09-28-2011, 12:29 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Vacuum leak. Check intake belly pan gasket.
