Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V6 Specific Topics
Old 06-29-2012, 05:46 PM
ryand73 ryand73 is offline
Vehicle: 1999 dodge ram 1500 3.9l
Color: green
ryand73 is on a distinguished road
cool thanks again that is pretty cheap i only have one o2 do i need left or right they offer both you put up left
Old 06-29-2012, 06:36 PM
emjohn4 emjohn4 is offline
Vehicle: '12 Ram Sport CC / '02 Durango
Rep:154
emjohn4 has a spectacular aura aboutemjohn4 has a spectacular aura about
The number of o2 sensors depends on what emissions package you have on the truck, Federal or CA.
Federal emissions has one cat; and one pre-cat and one post cat o2 sensor.
CA emissions has two or three cats, and two pre-cat and two-post cat o2 sensors.
You only need the upstream...if you have CA emissions, you need both; if you have Federal emissions, you need one.
Old 06-29-2012, 09:38 PM
Color: green
what i am wondering is that will one wire be longer than the other left longer than right or the other way around
Old 07-06-2012, 09:07 PM
Color: green
all right guys i just ordered the denso o2 sensor from rockauto i also checkedfuel pressure when you turn the key to the on position it reads 48psi when i turn the engine on it bounces from 48 to 52 so i think the fuel pressure is good ill be on later to let you know if the denso solves the problem if not next step check compression i want to thank everyone for the help ive been getting here this is the best fourm on the internet
Old 07-16-2012, 11:26 PM
Color: green
alright i got the denso o2 sensor on got 2 miles down the highway my reader picked up a misfire no light yet the misfire is starting at #5 I did a compression test all seems normal #'s 2, 4, 6 are all around the 155lbs. range # 5, 3 are at 160 and # 1 is at 150 how long does it take for the new o2 sensor to correct if the other was bad i got about 20miles right now ill be driving to work tomorrow so ill put about 70 miles on round trip any ideas will be greatly appreciated im starting to think fuel injector when i pulled spark plugs to do compression test they was all pretty white they have about 4200miles on them thats lack of fuel right
Old 07-17-2012, 07:26 PM
Color: green
ok guys i did a view enhanced diagnostics on the pcm with the obdII reader i came up with a P0351 coil A/secondary circuit and a P1282 fuel pump control circuit could this of popped up because of the compression test i did or could this be the reason for the misfire bank 1 issues i pulled the fuel pump relay and the wire on top of the coil pack to do the compression test these codes were not there before
