Old 04-25-2011, 02:18 PM
southpaw5m's Avatar
southpaw5m southpaw5m is offline
Vehicle: 2003 dodge ram 4.7L
Color: Patriot Blue Pearl
Rep:23
southpaw5m is on a distinguished road
Default Rear shock removal
Alright well I got to installing traction bars and got all new shocks since I was taking apart the rear end anyway and to cure my horrible wheel hop issues. But, I can't seem to get the rear right shock off for nothin! I finally got the bolt to move after three hours of nothing and the damn nut with the metal thing that is supposed to keep it from moving is bent now and turning with the bolt. I can't seem to get under the truck fat enough to see the nut and get a hold of it. Any suggestions from past experiences?
Old 04-30-2011, 08:30 PM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
I'm not sure about your truck but my understanding is that the 4th gens need to have the bed removed to get to the upper shock bolts...
Old 04-30-2011, 08:56 PM
You might end up cutting this one off.
Old 05-01-2011, 05:00 PM
southpaw5m's Avatar
Rep:23
I actually used some mass air flow cleaner and sprayed it real good and then took a deep socket wrench with a three inch extension on a ratchet wrench and then took a metal bar and used it as a breaker to get it loose. Then zip tied a open end wrench to the nut and pulled on it for three hours until it came budged loose then wrenched the damn thing off! Took me almost two days it felt like it was welded on. Eight years without being removed really does work on those things. But got my new shocks on finally and I only drove it in and out of my garage but it already has a night and day difference in the driver seat. So much stiffer. Can't drive it around yet until I fix this traction bar clearance problem I am having...
Old 05-01-2011, 05:18 PM
nYmPhMoBiLe08's Avatar
nYmPhMoBiLe08 nYmPhMoBiLe08 is offline
Vehicle: 2008 Dodge Ram
Color: Metallic Gray
Rep:75
nYmPhMoBiLe08 will become famous soon enough
I just replaced my rear shocks last weekend and you need to lift you truck from the hitch as far as you can just before the rear wheels come off the ground. They are under lots of pressure so they need to be fully extended then give them a good yank and they should come right out!
~Landon~
Current MODS: | Bilstein 5100's (Front) | Monroe Coil Overs (Rear) | Tow Mirrors | Husky Tool Box | Plasti-Dipped Badges/Gas Cap | 295/70/17" Nitto Trail Grapplers | 17X9" Fuel Boost Wheels | 3" DMH Cutout | RT Stripes \\ | WeatherTech Floor Liners |
dodge ram 1500 reg cab removal of rear speakers rammin her Custom Dodge Ram Interior Modifications - Custom Audio / Video 15 02-09-2015 01:49 PM
Rear Rotor Removal mydodgers88 Brakes 1 06-09-2010 07:14 PM
Rear resonator removal boyscout Exhaust 10 06-03-2010 02:14 PM
2006 Rear rotor removal? Sparky Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 1 05-21-2010 03:39 PM
Help with rear seat removal? skampedest Custom Dodge Ram Interior Modifications - Custom Audio / Video 4 06-22-2009 08:27 AM
