Old 04-24-2011, 11:27 AM
69speeder69's Avatar
69speeder69 69speeder69 is offline
Vehicle: 2001 Dodge Ram
Trim Level: Laramie SLT
Rep:18
69speeder69 is on a distinguished road
Default Spider Gear
So I changed the gear oil in my rear diff. And noticed that I had a broken tooth on my bottom spider gear. Is this something that I need to change asap. Or is it just gonna continue to be noisy while i drive.
Old 04-24-2011, 12:24 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
I'd get that fixed up asap! Not only will she continue to be noisy, she will get louder and eventually chew the hell out of the rear end. Especially if another tooth breaks off and stays somewhere in the carrier.
Big Red my old 2011 Sport
Old 05-30-2011, 09:25 PM
Rep:18
Can anybody explain the steps to changing out the spider gears. And is it something that i might be able to do in my driveway?
Old 07-08-2011, 10:13 PM
Tooadvanc3d's Avatar
Tooadvanc3d Tooadvanc3d is offline
Vehicle: 2006 Ram 1500 bighorn edition
Trim Level: BigHorn
Color: Inferno Red
Tooadvanc3d is on a distinguished road
Take off brake rotors remove cross pin in carrier. Its the pin that runs thru spider gears push in axle shafts to remove c-clips then remove spider gears. Reverse process to re-install
Found out I have a recall :( SslagleZ28 Dodge Ram Recalls and TSB's. 4 03-21-2011 12:23 AM
TRANSMISSION LOCKED IN 4th GEAR Studbuster 2009 Dodge Ram Forum 2 02-05-2011 08:21 PM
45RFE sensors and rear gear change partymn Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 3 11-28-2010 07:45 AM
Backlash setting ccdelay 5.2L V8 Specific Topics 1 09-06-2010 12:02 PM
rear diff philjohn 4.7L PowerTech V8 Specific Topics 26 06-27-2010 09:09 PM
