Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 04-25-2011, 11:26 AM
K. Meharg K. Meharg is offline
Vehicle: 2003 Dodge Ram 3500
Color: green
K. Meharg is on a distinguished road
Default '03 Fuel problems?
I have a '03 Ram 3500 quad cab, with a 5.9 Cummins and a 4:10 gear. The truck is a pulling nut, moving gross weights of over 20,000# on many trips. I started having what I thought was a fuel problem last December, but to date we have not been able to track it down. The truck will run perfectly for 100 or more miles, sometimes up to 500, and then it will seem to begin starving for fuel on big grades, going way down on power. It seems that when it starts this, the longer you run it the worst the problem becomes, sometimes slowing to an absolute craw going uphill. You can pull over, shut it off for a few minutes and the problem will go away for a period of time, or in some cases, will disappear altogether for the duration of the trip.
I have had the truck in the shop on two different occasions, with the computer showing no codes whatsoever. I have been told that it could be the fuel transfer pump, or the computer. Any ideas?
Old 04-28-2011, 10:07 PM
Pull Ya's Avatar
Pull Ya Pull Ya is offline
Vehicle: 2013 Dodge Ram Laramie 4x4
Rep:365
Pull Ya is just really nicePull Ya is just really nicePull Ya is just really nicePull Ya is just really nice
Install a fuel pressure gauge. Check your fuel filter. The lift pump may be going out, but usually they just crap out--now it works, now it doesn't.
Jay
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected. Remember, going fast costs money, so how fast do you wanna go?
Semper Fi Forever
Old 04-29-2011, 02:14 PM
Color: green
Thanks for the reply Pull Ya! I have changed the fuel and air filters a number of time with no result. Fuel pump? Maybe, but I feel the same as you, it should either work or not work, not heal itself during a brief stop. The fuel pressure gauge is an idea, may go ahead and do just that. Someone else suggested that it could be a bad fuel line that is partially collapsing during high fuel usage periods
This problem is about to make me start pulling out my hair!!!!!!!!
Old 04-29-2011, 02:41 PM
jgshannon jgshannon is offline
Vehicle: 2005 Dodge Ram 1500
jgshannon is on a distinguished road
Yeah, I would think it would be the fuel pump going out. I would assume the fuels moving around on those large grades and making it work harder, not that I'm a mechanic by any means lol.
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 04:16 PM
Fuel Fill Nozzle Shuts Off RamTech Dodge Ram Knowledge Base 3 11-22-2013 09:22 PM
96 Ram refuses to start. Fuel pump problems? Derek 5.9L V8 Specific Topics 9 11-28-2012 03:06 PM
Fuel fill problems RamTech Dodge Ram Knowledge Base 3 01-09-2010 10:38 AM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 12:36 PM
