Old 04-25-2011, 09:39 PM
gjayf77 gjayf77 is offline
Vehicle: 2013 RAM 1500
gjayf77 is on a distinguished road
Default Rattle in dash
I have a rattle in my dash, its coming from the top above the radio.. sounds almost like a rattling can if i put pressure on the area it goes away, anyone else experience this?
Old 04-25-2011, 09:43 PM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
ive got something rattling, but sounds further to the passenger side...definitely dash area tho
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 04-25-2011, 09:45 PM
MTtruckr's Avatar
MTtruckr MTtruckr is offline
Vehicle: 2009 Ram 5.7L
Trim Level: Big Horn Package
Color: Stone White
Rep:50
MTtruckr will become famous soon enough
I have a rattle in the same area. I'd like to hear if anyone has it figured out.
BDS 6 inch. Fox 2.0 rear. Toyo MT 35x12.50x18. Yukon 4.56's. Detroit Truetrac. Mufflex 18. Airaid CAI.
Old 04-25-2011, 09:50 PM
Sounds like there might be a small defect or assembly issue then. We ran into the same problem on the 300 cars....it was the clips below the defroster panel.
Old 04-25-2011, 10:10 PM
glad to see im not the only one then... anyone else have it? let us know
Old 04-25-2011, 10:32 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
I punched the dash this weekend in annoyance and it went away
Old 04-27-2011, 12:08 AM
rodanst6 rodanst6 is offline
Vehicle: 2014 Dodge Ram 1500
Trim Level: Limited
Color: Blue
rodanst6 is on a distinguished road
Been there, done that!
Old 04-27-2011, 06:33 AM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Vehicle: 2014 Ram 1500
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
I have a rattle above the passenger side dash speaker. It goes away if someone puts their hand on the speaker grill.
Old 04-27-2011, 02:52 PM
Whiplash's Avatar
Color: Black Gold
Rep:177
ya, that's about where mine seems to be coming from...
Old 04-27-2011, 04:04 PM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
At least you seem to have found the area where yours is coming from...I have removed my dash panels and center counsel, about ten times now...I have removed my radio, and just about everything else I could remove...I've taped, padded and zip tied, everything I could find including the factory wiring & shift linkage, that even appeared to wiggle, or looked like it could possibly make any noise, yet my noise is still there....Everytime I hit a rough road surface, or bump, it makes it's noise.....Sounds like it's coming from either below my floor mounted shift linkage, or from behind the heater or radio area, can't pin point it, or stop it....makes me nuts!!!!
It has a sound that I would discribe as a sound similar to electrical sparking, that's not what it is, but thats the best way I can discribe the sound it makes, it's pretty loud....I've tried holding everything, to see if I can locate the noise, no luck, it either must be someplace I cannot access, or inside some other component, that I cannot move to duplicate the noise....Like I said, I have taken almost my entire dash and consel apart about ten times now....I guess I will just have to live withit until someone comes across the sourse.....It's the only thing I dislike about my Ram
So it is written ! So it shall be done!
How do you pull the dash out? v10madness433 Body & Interior 23 04-06-2013 04:02 PM
Rattle in dash tnmopar Body & Interior 42 09-18-2012 07:14 PM
1994 CTD Dash Replacement johnny0874 Body & Interior 15 04-09-2011 10:22 PM
97 1500 Dash Replaced! brewman Dodge Ram Knowledge Base 3 02-05-2011 01:41 AM
Dash removal. Dieselkiss Body & Interior 0 03-11-2010 08:57 AM
