Old 11-15-2011, 11:31 AM
canuck1 canuck1 is offline
canuck1 is on a distinguished road
Default dashboard rattle
I'm not sure if this will help others but I finally found my rattle that I have lived with for far too long. While I was driving my rattle would sound like it was coming from the passenger side but if I leaned to the passenger side it would sound like it came from the driver's side. Turns out it was a clip in behind the ceiling right above the left bracket for the passenger sun visor. I just had to push up with a little force and it clicked into place. If you sit backwards in your seat and look up at the top of the windshield check that the gap between the ceiling material and the windshield is the same all the way across if it is not then there is probably a clip that is not in place. Hope this helps other people as well.
Old 12-06-2011, 06:27 PM
djbirri
Any further thoughts on this topic? MY 2010 has a rattle that seems to be wind turbulence related. If I go over rough road no rattle however, as soon as I hit 45 mph or higher on the highway the mysterious passenger side rattle appears. It also sounds worse when there is a cross or head wind. A slight vibration is felt in the passenger side floor board that seems to coincide with the rattle. Is there a plate or shroud of some sort that can be hitting the underside? I am going nuts!!
Old 12-09-2011, 01:40 PM
jandave jandave is offline
Vehicle: 2011 dodge ram 1500 QC 4x4
jandave is on a distinguished road
Yeah... add me to this list as well. The rattle didn't rear it's head until around the 12K km mark, and it is definitely located from the dash. It also only seems to occur around the 1500 to 200 RPM range. From what I've read on this thread, it sounds like it may be one of those clip instances.
VERY annoying!
Old 12-18-2011, 11:28 PM
ram@harley ram@harley is offline
Vehicle: 2012 ram 1500
Trim Level: express
ram@harley is on a distinguished road
Default 2012 ram
I have the same rattle passanger side. I was thinking windshield. Only has 200 miles.
Old 03-25-2012, 10:45 PM
xjayx88 xjayx88 is offline
Vehicle: 2012 sport
xjayx88 is on a distinguished road
I have the same issue on my brand new 2012 one. It's very annoying and stops when you keep pressure on it. I tried to punch it but it doesn't seems to help. Anyone knows how to fix it ?
Old 03-27-2012, 11:02 PM
roar84 roar84 is offline
Vehicle: 2011 Dodge Ram Crew 4X4
Trim Level: SLT Big Horn
Color: Mineral Gray Met.
roar84 is on a distinguished road
I have had this same "rattle" noise for a while. More noticible when the temp is cooler. It sounds like it is coming from above the driver's side speaker on my truck. Pushed down on the dash above speaker and noticed that the foam under the windshield also moved when I pushed down on the dash.
I wonder if when I go over bumps if the foam is rubbing on the inside of the windshield.
Looking for any input if this could be the issue or if anyone has located the exact problem. I have tried other suggestions in the is thread but no luck.
Thanks
Old 03-28-2012, 08:38 AM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Let us know how you make out and please keep us updated.....
Old 04-10-2012, 01:55 PM
Hiredgun Hiredgun is offline
Vehicle: 2012 Ram Big Horn
Hiredgun is on a distinguished road
I found and joined this forum searching for a cure for the passenger side rattle on my 2012 Ram. I happy to make my first post one that will hopefully help some of you rid yourselves of the mind numbing rattle that so many seem to suffer from.
Mine started rattling at about 400 miles. It drove me insane that a $41K truck had such a rattle. Like the rest of the posts I've read I felt it was coming from the dash. It ended up being my hood! Driving down a bumpy road I decided to pop the hood (while driving) to see what happened and the noise completely went away.
To fix it I simply adjusted the rubber hood bumpers up on the front support, sprayed some graphite grease on the hinges and that did the trick! It's odd to me that the sound traveled into the cabin as it did.
I hope this helps someone out there. This is a great site!
Old 11-17-2014, 02:09 PM
DavidJ01 DavidJ01 is offline
Vehicle: 2011 Dodge Ram 1500
DavidJ01 is on a distinguished road
My 2011 1500 just developed the rattle, where it seems to be coming from behind the dashboard on the passenger side. I've tried muffling every moving piece of plastic trim or cowling I can find on the outside, starting with the wheel wheel, the mud flaps, the air dam around the windshield, etc... I've pressed and banged on nearly every square inch of the dashboard with no (favorable) results. And I've taken out the lower portion of the glovebox in hopes of getting better access to what's behind / under the dashboard, and I've removed the plastic side trim to try and find the offending part. Still no success.
What I need to do next, is to remove the upper portion of the glove box. I see one screw underneath, and several tabs with metal clips on them, but I can't seem to get them loose. Any idea on how to remove the upper portion of the glove box?
PS... I should mention that I only hear the rattle as I exceed speeds of 30mph, and that it doesn't matter what type of road surface I'm on. So I feel it's definately wind related.
Thanks
David...
Old 12-22-2014, 09:45 PM
plumberboy's Avatar
plumberboy plumberboy is offline
Vehicle: 2014 Dodge Ram quad cab
plumberboy is on a distinguished road
Yup I got the same problem in my truck, right in the middle of the dash and it drives me nuts.
How do you pull the dash out? v10madness433 Body & Interior 23 04-06-2013 05:02 PM
Rattle in dash tnmopar Body & Interior 42 09-18-2012 08:14 PM
1994 CTD Dash Replacement johnny0874 Body & Interior 15 04-09-2011 11:22 PM
97 1500 Dash Replaced! brewman Dodge Ram Knowledge Base 3 02-05-2011 02:41 AM
Dash removal. Dieselkiss Body & Interior 0 03-11-2010 09:57 AM
