Old 04-25-2011, 10:51 PM
ND RAM ND RAM is offline
Vehicle: 2011 Dodge 1500 Crew Cab 4X4
Trim Level: SLT Big Horn
Color: Mineral Gray
ND RAM is on a distinguished road
Default For The Life Of Me!!!
I CANNOT seem to find the "display" for instant or average fuel mileage.
I can call up the Coolant Temp, Oil Temp, Transmission Temp, Hrs. of Running and maybe one more. There must be a "sub-menu" that I'm missing.
OK, try and walk me through this. When I hit the "Back" button where do I go from there, step by step.
I'm almost losing sleep over this, but not quite!!!
Thanks!!!!!!!!!!
Old 04-25-2011, 10:57 PM
aunglesbee412's Avatar
aunglesbee412 aunglesbee412 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:15
aunglesbee412 is on a distinguished road
When you back all the way out to the main menu where you can select tire pressure and messages and all the temps. The fuel eco is at the very top under the current radio station that is playing. Hit the arrow to the right and it will pop up with the bar at the bottom to indicate how much it varies based on acceleration. Hope this helps some.
Old 04-25-2011, 11:00 PM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
I believe its under the fuel economy menu if I am not mistaken. got back as far as you can and i think its the top option.
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 04-25-2011, 11:12 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
This is my answer too - The eco can be reset by hitting the arrow to the right a second time.
Old 04-26-2011, 09:52 AM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
ND Ram, go to your setup menu in the EVIC, in there you can turn on or off the fuel savings menu. I was playing around in there on the weekend and stumbled across that setting.
Worst part is that the setting disappears in the setup menu when you turn it off, it should be at the very bottom of the setup menu.
Big Red my old 2011 Sport
Old 04-26-2011, 10:48 AM
RedDodge's Avatar
RedDodge RedDodge is offline
Vehicle: 2014 Dodge Ram
Color: Granite
Rep:25
RedDodge is on a distinguished road
Use the "back" button on the right to get to the main menu, then use the up/down keys on the left to toggle through the different options. As said, the "fuel economy" is near the top of the scroll options. Then use the "select" key on the right to enter into the screen.
Steve
www.monteman.com
Mods: Tinted front windows, UnderCover tonneau bed cover, step rails, bed mat, cabin air filter, 4 corner mud flaps, slush mats, drop in K&N filter.
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 01:59 AM
L.E.D bulb Replacement bones64 Custom Dodge Ram Interior and Exterior Lighting 18 03-05-2012 08:51 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 03:43 PM
Life RootBeer Jokes/Humor 6 08-12-2010 10:22 PM
Celebrate Life.......Everday bones64 Off Topic Discussion 11 01-13-2010 12:58 PM
