MOPAR DECALS
Old 04-25-2011, 11:20 PM
Bnixon's Avatar
Bnixon Bnixon is offline
Vehicle: 2008 Ram 1500 QCSB 5.7L Hemi
Color: Gray
Bnixon is on a distinguished road
Default 2/4-2/5 drop kit, best ride quality?
Hello,
I have searched the forum on drop kits and have found contradictory info. I have a 08 QC 1500 2 wheel drive and looking for a mild drop to improve the handling of the truck. But I do not want to kill the ride quality.
I am bouncing between the Belltech 2/5 (spring) and McGaughys 2/4.5 (spindle or spring).
I hear that there are issues with the spindle kits. What are the known problems?
I also hear that the coil spring kits will return a rough ride.
Those out there with these kits, can you give me feedback on the ride quality?
I am looking for feedback to help me make a decision on which way to go. My intentions are to get gunmetal SRT reproduce wheels 22x11 with 305s.
Would greatly appreciate you input and experience.
Brandon
2008 Ram 1500 QC 2wd, McGaughy's 2/4.5 drop, Belltech Rear Anti-sway bar
Old 04-25-2011, 11:30 PM
iRESQu iRESQu is offline
Rep:2217
I did a 2/4 BellTech drop kit on my '11 and was looking to do 22" SRT rims as well, but went against that after I read some reviews on here. Just "search" 22" srt rims and it should pull up some member conversations about them. There is a lot of discussion about wheel hop and rear shifting "traveling". Best of luck.
Old 04-26-2011, 01:21 AM
davidmh13's Avatar
davidmh13 davidmh13 is offline
Vehicle: 2008 dodge ram qc
Trim Level: lone star
davidmh13 is on a distinguished road
i have the 4/6 mcgaugheys kit (spindle AND spring) and the ride quality isnt really that bad. its definitely different, feels sportier for lack of a better word, but if you do it the right way i dont think you should have too much complaint.
Old 04-26-2011, 08:36 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
What issues have you heard with Spindles on these trucks? The only concerns i have is the weight of the spindles and having some clearance concerns on certain 17 rims. Nothing a little grinding cant fix on the latter.
Old 04-26-2011, 01:50 PM
Bnixon's Avatar
Color: Gray
I read that they make the wheels set out further that stock. I also heard about the clearance issues on small er wheels but that doesn't concern me as I will be going with 22" SRT.
I want the truck to feel sportier I just don't want to have the truck hopping down the road. I had a 2004 Ram QCSB 2500 5.7 4x4 with extra helper spring in the rear. That thing road rough and was the reason I went with the 2 wheel drive 2008 Ram QCSB 1500 that I have now. But my 2500 4x4 handled 200% better than my current 08 1500! The 1500 is like a boat going around the corners and has terrible bump steer at highway speeds! This is what i want to fix. Make it handle better but not get back the bumpy ride (Mainly the rear end).
I will need to look up the SRT wheel issues iRESQuI talked about.
Old 04-26-2011, 02:56 PM
Color: Satin Orange
Rep:627
Spindles will also keep it very close to stock geometry vs springs where you may issues with alignment.
The drop will lower the center of gravity but shocks is what will make a difference in the way the truck will ride. In addition, adding a rear sway bar will dramatically change the way your vehicle corners due to taking away a very high percentage of body roll.
If you still have axle hop then caltracs can take care of that.
Old 04-27-2011, 11:14 PM
Bnixon's Avatar
Color: Gray
So the progressive rate springs don't effect the handling all that much?
Do you know if the pushing out of the wheels is real?
Kay9, do you have spindles on your truck? If so what has been your experience?
iRESQu, so you say this is related to the 22 SRT wheels? "There is a lot of discussion about wheel hop and rear shifting "traveling"" I did a search but didn't come up with any negatives on the SRT wheels. Must not have used the right key words. Do you have a link to the discussion on this issue(s)?
Thanks for the feedback, I really value your experience and opinions!
Brandon
Old 04-28-2011, 09:03 AM
Rep:2217
Brandon
Of course I say something that typically wasn't hard to find and now I can't find it. I am doing research and I WILL get back to you. I might have to just pm you the info. Give me a couple of days at most and I will have answers for you, PROMISE! The "search" sucks.
Old 04-28-2011, 09:19 AM
Rep:2217
Here is one that slightly hits on the subject:
http://www.ramforumz.com/showthread.php?t=80373
http://www.ramforumz.com/showthread.php?t=79752
These are the two I can find now.....still looking.
Old 04-28-2011, 09:56 AM
Bnixon's Avatar
Color: Gray
Wow! Thanks for the links!
So has anyone determined the actual cause of the bump steer/skating? Is it the rear or front suspension that causes it?
I would think that if cutting the rear coils solved the problem for Chithead then the rear suspension is the culprit. So maybe it is rear wheel hop? Has anyone really identified what the geometry issue is on these trucks?
Snowplowing with my 1500 johnf15 2010 Dodge Ram Forum 7 11-29-2012 04:32 PM
Fave Poems or Song Lyrics erm Off Topic Discussion 210 07-31-2011 10:33 PM
Anyone with stock Alpine, Swap to Quality Spekaers but Retain the Amp? RammD Custom Dodge Ram Interior Modifications - Custom Audio / Video 22 08-12-2010 08:45 AM
Got the GroundForce 2/4 drop installed CdnoilRAM Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 19 06-18-2010 12:16 PM
