Old 04-26-2011, 12:48 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Default Programmer, EPS and Traction Control
Okay, so this weekend, I was helping a buddy out in his pasture, and ended up in a mud hole maybe 8 - 10 inches with a fairly solid bottom. In my old Jeep, I would have went right through this without breaking a sweat. Granted I have stock tires, but even in 4wd I had a hard time getting out because of the stupid traction control and EPS. 4 LO didn't give me enough wheel speed to get out, so I went back to 4 HI and found that i can turn off the EPS by holding the traction control button for 10 seconds or so. However, it was still doing something, because I couldn't change between forward and reverse quickly because there was a whining groaning noise (kinda like when you have the brakes on, and then just barely let off). It would last maybe 5 seconds, and by the time it stopped and I changed directions, all momentum was lost.
Will a programmer completely disable all this junk for city yuppified never been off road drivers, so those of us who plan to USE our truck, can? I had a Chevy mechanic with me and he said the new GM's do the same crap. Why can't they make trucks for those who want to work with them?
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 04-26-2011, 05:05 PM
Pull Ya's Avatar
Pull Ya Pull Ya is offline
Vehicle: 2013 Dodge Ram Laramie 4x4
Rep:365
Pull Ya is just really nicePull Ya is just really nicePull Ya is just really nicePull Ya is just really nice
You'd have better luck with a Power Wagon. If you want something functional you'll probably have to build it yourself--or buy a winch
Jay
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected. Remember, going fast costs money, so how fast do you wanna go?
Semper Fi Forever
Old 04-27-2011, 10:09 AM
Wildcat's Avatar
Rep:166
I thought about a 3/4 ton, and especially the Power Wagon, but the price was a bit much. Plus the ride wasn't near as nice. I can add a winch, lift, tires, lockers, gears, but I am still stuck with a truck that doesn't want to go when it gets off the paved road into something slightly slippery.
I didn't realize I would stump everyone with this question. How can they build a 4wd truck and add a feature that renders it helpless off road? I think the button should have been to turn on traction control, make it the exception and not the rule. It is nice at highway speeds when you might hit a slick spot, but no other time do I want it, nor think it is necessary.
Old 04-27-2011, 10:14 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
The programmer will disable MDS...not sure about the traction control.
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 04-27-2011, 11:17 AM
Pull Ya's Avatar
Rep:365
I assume that in their research they found that most 1/2 tons were used on the highway and not to do real "4 wheel driving and work". Most probably won't even see a dirt road or drive through a pasture. I guess they figure if you want a "real" truck to work with and go 4 wheel'n with you would buy a 3/4T although you will have to give up the soft ride. After 3 3/4 cummins I am still trying to get used to my 1/2T. It's a completely different type of "truck". I am learning to except it's limitations.
Jay
Semper Fi Forever
Old 05-11-2011, 09:21 PM
rammitt's Avatar
rammitt rammitt is offline
Vehicle: 2010 RAM 1500 quad cab 4x4
Trim Level: Bighorn SLT
Color: Rugged brown pearl
rammitt is on a distinguished road
Default Wheel Spin Limiter?
I totally had the same "problem". I was out ELK hunting and went down in a slippery ravine and needed max wheel spin to get out and just couldnt get it with all this B.S on this so called truck. I spoke with the Dodge REP when he was on live here one day and he really didnt have any solutions other than to say" it does have a wheel spin limiter to protect the truck"....WHAT???? If I want to blow the truck up, that should be my choice. I am really disappointed in this truck and all its shortcomings. So, you have a HEMI but you cant use it when you NEED IT! WORTHLESS!
MOLON LABE
Old 05-11-2011, 10:10 PM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
esp is a safety feature it is federally mandated, all cars come with it standard. basically it is some bs put into play by the govt to help lower insurance claims. The best solution i have for your problem is to remove the drive by wire, unfortunatly there is no previous model to retrofit from so u would be stuck fabricating then using a different computer capable of maintaining idle and monitoring throttle position. hell if u wanna go even more antique a carburator would do the trick!
Too many mods to fit here!
Old 05-17-2011, 05:08 PM
Wildcat's Avatar
Rep:166
It looks like the DSP will deactivate all the traction junk, including the ABS. I am fine with this, since the places I need it off, I really won't need the ABS either. Anyone with a DSP that can confirm this?
Old 05-17-2011, 10:45 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
DSP won't disable abs. It does reduce TM but to disable abs you gotta unplug a wheel sensor.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 05-18-2011, 07:48 AM
VA4MEDS's Avatar
VA4MEDS VA4MEDS is offline
Vehicle: 2010 5650 lb LeadSled
Trim Level: LeadSled
Color: Austin Tan Pearlcoat
Rep:48
VA4MEDS is on a distinguished road
Thumbs up
WRONG.... DS with 9t12b crom is the new update and it DOES disable ESP & ABS. There is a menu for this. It works great at the strip.
N2O/Nitro-Meth is like a Hot Chick with a STD.. You know what will happen if you hit it..But you just don't care anymore..
'10 5680 lb LeadSled CC - 13.401 @ 100.460 MPH...Custom Tunes by white lightning...Pushed & Chilled by Mr. Freeze
