Radio removal - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 04-26-2011, 12:50 PM
wildbill wildbill is offline
Trim Level: SLT Big Horn
wildbill is on a distinguished road
Default Radio removal
I have been unable to locate instructions as to the procedure for removing radio trim pieces in my 2010 dodge ram. I have ordered a uconnect kit which I will have no problem installing if I could only figure out how to remove radio trim. My truck has 40/20/40 seating. Thanks.
Old 04-27-2011, 12:21 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
I don't have the procedure, however am interested in your Uconnect Kit installation. Hopefully someone will get some answers for you soon.
Also a warm Welcome from the North Carolina - drop in the the Newbie Checkin to introduce yourself.
Old 04-27-2011, 01:20 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
NOTE: For REQ radios, turn ignition to RUN and press the SET + SCAN buttons simultaneously to place the radio into transportation mode. The radio will display "Transportation" on the display within 5 seconds. If the radio is inoperative or not REQ, skip this step.
1. Disconnect and isolate the negative battery cable.
2. Remove the upper and lower center bezel tray liners (1).
3. Using a trim stick C-4755 or equivalent, disengage the retaine clips that secure the power outlet trim bezel (1) to the center bezel (2).
4. Remove the five center bezel fastners(1).
5. Using a trim stick C-4755 or equivalent, disengage the retainer clips that secure the trim ring (1) to the floor console.
6. Using a trim stick C-4755 or equivalent, disengage the retainer clips that secure the shifter bezel (1) to the floor console
7. Using a trim stick C-4755 or equivalent, disengage the retainer clips that secure the instrument panel center bezel (1) to the instrument panel.
8. Disconnect the wire harness connectors (4) and remove the center bezel from the vehicle.
9. Remove the radio mounting fasteners.
CAUTION: Pulling the antenna cable straight out of the radio without pulling on the locking antenna connector could damage the cable or radio.
10. Disconnect the antenna cable(s) by pulling the locking antenna connector away from the radio.
11. Disconnect the electrical connectors.
brad
Interested in one of my mods?
Old 04-27-2011, 01:39 AM
jbryan2's Avatar
jbryan2 jbryan2 is offline
Vehicle: 2001 Dodge Ram 1500 4x4
Trim Level: 4x4
jbryan2 is on a distinguished road
Check this link out step by step instructions http://www.pro-fit-intl.com/Adobe/DG-92-08-G3-p9.pdf
Old 06-10-2011, 01:15 PM
RBPPowerWagon's Avatar
RBPPowerWagon RBPPowerWagon is offline
Vehicle: 2010 Power Wagon
Trim Level: Power Wagon
Rep:87
RBPPowerWagon will become famous soon enough
amazing walk throughs
RADIO REMOVAL for 2009-2010 DODGE RAM 1500 kjobrien84 2010 Dodge Ram Forum 16 10-07-2012 09:54 PM
Radio removal for 09 Ram NAV-TV NAV-TV - MyGIG Integration - Dodge Ram Accessories 9 09-21-2012 10:04 AM
Activating Side Heated Mirrors & Radio Traffic Warning Sign removal? RammD LD RAM - General Discussion 2 07-31-2010 01:28 PM
Radio Trim Removal for LockPick install? bikewv 2010 Dodge Ram Forum 2 06-18-2010 10:53 PM
Any DIY on removal of stock radio with pics for 2005 Ram THE TALLIT MAN Custom Dodge Ram Interior Modifications - Custom Audio / Video 6 06-10-2010 04:46 PM
