Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Tuning Discussion > Diablo Predator Questions & Info!
Place your Ad Here!
Old 04-26-2011, 12:50 PM
Crash Crash is offline
Vehicle: 2016 Laramie Longhorn Limited
Trim Level: Laramie limited
Color: Black crystal pearl
Rep:404
Default DSP disables ESP??
Hello all, I see we have a new site sponser advertising the DSP and in his description of the product he claims it will enable/disable ESP. I PMed him questions in regards to this and price and he sent me back a reply with a supposed quote from DS
"Quick Adjust parameters
Quick adjust parameters do not require a reflash to take effect, they require a key cycle, these parameters are available in a separate "Quick Adjust" menu item as well as in the modify parameters menu.
User will be asked to cycle key after each adjustment.
  • ESP mode
    Enable or disable the ESP (traction control), NOTE: When disabled the ABS, ESP BAS and (Brake) lights will be illuminated and ABS will not be operational
  • Reset TCM adaptation
    Resets the learned TCM adaptation(instead of pulling a fuse).
  • Shift Points
    Raise shift points by a predefined setting, 5.7L's (1-2 5800rpm, 2-3 6000rpm, 3-4 6000rpm), 6.1L's (1-2 6400rpm, 2-3 6400rpm, 3-4 6400rpm).(N/A on Jeep)
  • Shift Firmness
    Reduces torque management between shifts for a firmer shift , N/A on SRT8 vehicles.
  • Autostick auto upshift
    Enable/Disable automatic upshift when in manual autostick mode, ie. raise your rev limits and you can shift manually at any rpm without the vehicle automatically upshifting (as it would do stock).(N/A on Jeep) "
I specifically asked him about a 2010 Ram. So is this true? or have I recieved wrong info.
Old 04-27-2011, 01:31 AM
TxPride911 TxPride911 is offline
Rep:27
TxPride911 is on a distinguished road
Yeah this is true. The only thing that really bothered me was having the ABS lights on and everything that deals with that. The ESP is a pain for sure and I wish I could disable it without the lights popping up or without having to buy a programmer, however its not possible and I don't feel like riding around in a $30k truck with all those lights on. Just depends how much it means to you I guess.
Old 04-28-2011, 05:11 PM
MADDOG MADDOG is offline
Rep:22
And it's not recommended that you run over the highway in ESP off mode. You will lose ABS functionality. Stopping distances will be longer and you may experience a loss of control due to skidding.
I only turn my SRT's ESP off when I am at the dragstrip!
Old 05-27-2011, 09:38 PM
Ferg's Avatar
Ferg Ferg is offline
Vehicle: 2010 dodge ram reg cab 4x4
Trim Level: sport
Color: deep water blue
Rep:31
Ferg is on a distinguished road
Has anybody loaded this tune and shut the esp off on there trucks? does it get rid of the soggy throttle response from a dead stop?
Old 05-27-2011, 09:48 PM
Rep:22
The Predator definitely improves throttle response, makes more HP and torque at lower RPM's and sustains them longer in the power band without disabling ESP.
Esp green1361 Newbie Checkin! 17 03-13-2011 08:02 PM
Esp bas saunders1986 Electrical 10 02-09-2011 11:18 PM
Esp and traction control problem daversv 2010 Dodge Ram Forum 12 02-03-2011 03:23 PM
