New Carrier? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-26-2011, 04:37 PM
darkraven72 darkraven72 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:62
darkraven72 will become famous soon enough
Default New Carrier?
I put the lift on and the 35's. I wanted to change the gearing. Dodge is telling me that I have 3.21's and 4Wheelparts is saying I should go to 4.56's.
The local shop is telling me that I will probably need a new carrier if I go that far.
SHould I need a new carrier? Is 4.56 the right gearing? I have a 2008 1500 2wd lifted 6 inches with 35's. I know I need new gearing, but 4.56 seems extreme. I tow a trailer on the highway once and a while.
Thanks.
Old 04-26-2011, 04:38 PM
Rep:62
Old 04-26-2011, 09:04 PM
dodgeguy's Avatar
dodgeguy dodgeguy is offline
Vehicle: 2000 Dodge Ram 1500
Rep:61
dodgeguy will become famous soon enough
I wouldn't do 4.56s. I would go with 4.10s.
You could even do 3.92s and be fine with the 35"s, but since you're going up anyways, you might as well go to 4.10s.
The 4.10s will be better on the tranny, and if you go bigger in the future, you'll want the 4.10s.
"If it's smaller than a 5-cyclinder, it's just a glorified motorcycle engine."
Old 05-11-2011, 09:46 PM
Rep:62
Well, I got the 3.90 gears. According to the shop, the carrier I had only allowed for certain gearing options. It was either what I already had, 3.90 or 4.55. So I went with 3.90.
I am happy with it so far.
Old 05-11-2011, 10:01 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
3.90 should be fine! My buddy has an 06 4.7 2WD that is lifted 6" with stock gearing...it works, but works hard!!!
Old 05-11-2011, 10:19 PM
Rep:62
Yeah, I had 3.21. The online calculators say I should go with 3.55, but I think I am better off with 3.90s. It has a bit more kick now, lol.
Old 05-11-2011, 10:45 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Sounds like a winner and from the looks of it the truck is awesome - how about a few for showing it off?
Old 05-12-2011, 06:43 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
4.56's aren't exactly overkill and would probably be wise if you plan on going any higher. But, if you're fine with your currrent height, 3.92's or 4.10's will get you by just fine.
Truck built, no railcars for transport? Electron Mike Dodge Ram R/T 35 05-17-2011 01:04 AM
Carrier 03Thunderroad 5.7L V8 Specific Topics 2 03-06-2011 12:13 AM
NeBad Rear Differential Carrier Assembly RandyF 2010 Dodge Ram Forum 9 10-04-2010 08:02 PM
Carrier bearing drop kit Powerback73 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 08-29-2010 02:21 PM
Need help with replacing Carrier Bearing GodsDsipl Suspension 0 06-29-2009 05:19 PM
