Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 04-26-2011, 08:51 PM
RamRod07's Avatar
RamRod07 RamRod07 is offline
Vehicle: 2007 Dodge Ram 1500
Rep:15
RamRod07 is on a distinguished road
Default 5.7?
Can't decide if I should do nitrous on my truck. I'm getting mixed signals. I figure if I keep it turned low and rarely use it it shouldn't do to much damage. Plus its a lot cheaper than the supercharger. I have a diablo predator, CAI, and exhaust. Any help would be greatly appreciated. I do want to keep my motor running good and not have to rebuild it.
Old 04-26-2011, 08:56 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
there are a couple of guys here runnin NO2 without any problems. I'd suggest nothing higher than a 75hp wet shot.
Old 04-26-2011, 09:01 PM
I push the skinny pedal
Rep:3277
Agreed, running N2O is perfectly safe if you keep it reasonable and purge the line everytime before use. Running a 75-100hp on a stock motor is well within the handling capability of the engine.
Kurtis
Old 04-26-2011, 09:04 PM
RamRod07's Avatar
Rep:15
What do you mean by purging? I'm looking at the Zex system and it hooks to my gas pedal and activates when open. I wanted to mount it under my truck.
Old 04-26-2011, 09:18 PM
CHVYKLR's Avatar
Rep:252
have you ever seen cars line up for a 1/4 mile run and before they launch you see a gas shooting up into the air right in front of the front window or front bumper. that is the driver "purging" the NOS line.
here's an example:
Old 04-26-2011, 09:23 PM
RamRod07's Avatar
Rep:15
So do I just hook the purger (not sure if thats the technical term) to a switch to purge it? I'm new to the nitrous thing if you can't tell.
Old 04-26-2011, 09:30 PM
CHVYKLR's Avatar
Rep:252
I haven't priced it in a while so I could a little off but to do a nitrous setup "correctly" you'll end up spending about $1k.
NO2 kit
purge valve
window switch
remote bottle opener (depending on where you mount the bottle)
bottle warmer (depending on where you live and how cold it gets)
am I forgetting anything?
Old 04-26-2011, 09:42 PM
RamRod07's Avatar
Rep:15
Not that I know of. Thanks thats really helpful!
Old 05-02-2011, 12:07 AM
Silver04Ram's Avatar
Silver04Ram Silver04Ram is offline
Vehicle: 2004 Ram 1500 4door 4x4
Color: silver
Rep:50
Silver04Ram will become famous soon enough
I run a 75hp shot through my 04 and its fine. Eventually i will go up to a 100hp shot but thats as far as i will take the stock motor. If you rarely use it you should be just fine. If you look at the wet kit jetting thread i have pictures of the way my kit is setup under the hood.
The Terminator with the dual purge through the snakes are awesome!!
2004 Ram: Straight piped,CAI,N20,smoked LED Third Light,H.I.D Off Road Lights.
1999 Z28: Forged 346,F.A.S.T 92/92 TFS 215's,.605/.609 112LSA TH400 3500stall, 3.73's, TNT F2 250shot...T-Tops Hate Me!!
Old 05-03-2011, 11:02 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I've run 100/125 shots alot... you can go as much as 150 and still be ok, anything over and you should reinforce internals.. agree with others and install a purge solinoid, it's insurance to make sure you bleed any air out of system..
