5.7? - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 09-11-2011, 02:15 PM
BadHazard's Avatar
BadHazard BadHazard is offline
Vehicle: 2006 QCSB, 1500
Color: Inferno Red
BadHazard is on a distinguished road
no internals? rods, pistons, heads, rings?
06 QCSB, 1500, Laramie, 4x4 50k. 18" Rockstars, K&N Drop in Filter, Muffler Delete, SuperChip
Old 09-11-2011, 02:20 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
not with a 75hp shot. there are guys running a 125-150hp shot on stock internals. as long as you set your timing correctly and don't run lean your transmission will probably let go first.
Old 09-13-2011, 09:56 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
gotta make sure your always running good fuel and your fuel system can handle the extra needs for the hit. I know of a lot of guys in the LSX world that spray 150 through a stock engine but put in a Walbro 225 in just for the extra nitrous demands. You could also run a stand alone dedicated nitrous fuel tank, but that is $$$
2011 Big Horn 4x4 -SnowWhite-
Old 09-15-2011, 12:58 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
maybe colder plugs like Ngk 4306's...75 shot is very small for the hemi...
Old 09-18-2011, 02:41 AM
Snafu Ken's Avatar
Snafu Ken Snafu Ken is offline
Vehicle: 2008 Bullitt Mustang soon Ram
Trim Level: owner soon
Color: owner soon
Snafu Ken is on a distinguished road
I think you must have a good bottle heater with a pressure adjustable shut off and a good nitrous gauge on the bottle and one you can see in the dash or post area. Next a good inline nitrous filter. Use only a wet kit with the better larger solinoids. I prefer a hand button usually in the gear shift area. A good visual arming switch that glows red when armed. I always used a good octane booster to stay on the safe side. Nitrous Express octane booster was my fav. My 2004 Hemi with Nitrous dyno numbers where 507 hp to the wheels. I ran it for 2 years with no issues. Nitrous user since 1993 with no blown motors. A good purge is a must also. I have ran both a single stage and a dual stage set-up but liked the dual stage with a delay timer best. I would leave on 75 hp with a 1 sec delay for stage 2 - 75 hp (total 150 hp) Usually mid 12,s.
Old 10-28-2011, 11:37 PM
chefred112's Avatar
Rep:656
I'm spraying 100-125 shots on my stock bottom end motor with over 205k miles on it..
