Old 04-27-2011, 01:48 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:83
Turbovsix will become famous soon enough
Default Lazy/non-existent downshifts - anybody else with this issue?
Hi Folks -
I've seen a few references on the board to this issue - wondering who has had their dealers look into the problem and what the fix was.
I'll be motoring along at 40-45mph, let's say on a highway on-ramp...time comes to punch it and accelerate into traffic, and the truck just won't downshift. I have to back off the throttle completely and hammer it - it's almost like it gets confused (at times, I'll notice this is when I'm coming out of MDS) and it'll just hold whatever gear I'm in. Makes for an interesting time merging onto some of the highways where I live.
Doesn't seem to be a mechanical issue - seems to me like it's just the shift logic/computer getting confused as to what it should be doing.
Are there any TBS's out there for this issue? I'm going in this Friday to have my L14 HVAC recall performed, and I was going to mention the tranny issue, but I'm sure they "won't be able to duplicate it".
Again, any others out there experiencing this and if so, was there a fix via a reprogram by the dealer?
Thanks in advance for the help!
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI - all stock!
2012 Jeep Grand Cherokee Limited
Old 04-28-2011, 12:41 AM
williamhartle's Avatar
williamhartle williamhartle is offline
Vehicle: 2007 dodge ram
Trim Level: st
williamhartle is on a distinguished road
i have an 07 and it would do the same thing i put a tuner in it and now its a lot better.
2 inch leveling lift 3 inch body lift, 34" bfg mud terrain TA KM2, straight pipe, vararam intake, superchips cortex, Firestone air bags, skyjacker n8000 shocks rear, s8000 front struts, painted head lights, tinted tail,cab mount light, big shiny chrome balls.
Old 04-28-2011, 01:35 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Can't say I've ever experienced that with mine. Even with moderate 'Go pedal' operation, it'll down shift as soon as the engine starts to work. I personally do not like automatic transmissions, but if i have to have one, the one I have is pretty OK.....at least I can manually shift if I have to.
brad
Interested in one of my mods?
Old 05-11-2011, 05:17 PM
rainhater1 rainhater1 is offline
Vehicle: 2010 ram 1500 4x4 06 300 srt8
Trim Level: slt - big horn
Color: light graystone
Rep:116
rainhater1 will become famous soon enoughrainhater1 will become famous soon enough
I have found that if I drive it in 5 it wont do that. hit one - on the shifter
Old 05-11-2011, 05:51 PM
PEvil's Avatar
PEvil PEvil is offline
Vehicle: 2007 Dodge Ram 1500
Color: Electric Blue
Rep:41
PEvil is on a distinguished road
Superchips with advanced transmission tuning will get rid of this and any other issue you have with the transmission. You have the ability to customize the shifting to your liking.
--Superchips 3865 with Advanced Transmission Tuning--K&N Drop-In Filter--Cat-back Exhaust--Sonnax Line Booster--Bilstein 5100 Leveling Shocks--Firestone RideRite Air Springs--AirLift Load Controller II--305/55/20 Nitto Trail Grapplers--
Old 05-11-2011, 11:20 PM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
Yea what rainhater said. shift from d-5 that'll make the tranny more mechanical. When u floor it your pedal sends a signal to the ecu it opens the throttle less quickly when in d, then the trans is told to shift or not to shift b/c wheelspeed is high, u might reach the governor blah blah blah. manual shift is as close to a sport mode as the auto insurance institute will allow.
Too many mods to fit here!
Old 05-12-2011, 12:26 PM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
I just noticed this happening this week to mine. Went to go around somebody and no guts stayed in the same gear, like I was driving a Chev
I had to floor it, and finally it kicked down but was very slow. First time it's happend to mine, hope it's not a pattern
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 05-12-2011, 06:07 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I have noticed this a few times, would take about 3 seconds or so to downshift upon flooring it, and I have superchips 93 tune. I only drove the truck about a week before the superchips so I don't know if it did it before. I also agree it seems like a computer or logic based issue, not mechanical. I also noticed my trans seems to slip slightly from 1st to 2nd, wheras other shifts are very firm...
Sean
Old 05-12-2011, 06:35 PM
Rep:2705
a month ago i took my '09 in for a shifting sort of grinding noise when going into reverse, they said that it was fixed, told me it was the drive shaft, i thought yeh right
now it is doing it shifting into all gears, sounds like a sloppy standard transmission linkage when a throw out bearing is starting to go bad
Glad that i bought the Lifetime Maximum Care Warranty
I'm saving up for when they come out with the ZF 8 speed & possibly a ZF rear end like in the full sized Jeeps, maybe by then the 6.4L engine will be an option
by this time next year, i should have at least $30,000 to spend on a down payment
Old 05-13-2011, 12:23 PM
Turbovsix's Avatar
Rep:83
Yeah, I guess the 1-2 shift is just engineered as really sloppy but yes, it's definitely a computer-based issue. I can sometimes duplicate it - around 45mph, coming out of mds and trying to downshift - I'll have to really floor it, then let off, then hit it again and THEN it'll downshift. It's caught me by surprise a few times merging into traffic. I'm going to have it checked out for what it's worth.
Rich -
Automatic Start Issue / Check Engine Light 07Ram 5.7L V8 Specific Topics 4 05-19-2011 07:46 PM
RUST issue with 2010 4x4 Ram Big Horn...anyone else having this issue SupermanWV 2010 Dodge Ram Forum 18 01-29-2011 10:42 PM
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-13-2011 12:30 AM
AAC Interior Light issue Quiet Lunatic Custom Dodge Ram Interior and Exterior Lighting 8 06-01-2010 09:58 PM
Dealer issue, being a baby or honest issue. cartert1975 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 31 04-09-2010 03:19 PM
