Old 05-02-2011, 08:31 AM
randallman randallman is offline
randallman is on a distinguished road
Originally Posted by rainhater1 View Post
Thats what I use and it works, move it from my coach to the ram and it works great in both
Rainhater1, can you perhaps post a pic of where you decided to mount the P2?
Old 05-02-2011, 10:01 AM
tmerritt530's Avatar
tmerritt530 tmerritt530 is offline
Vehicle: 2004 Ram 1500 4.7L "H/O"
Color: Graphite Metallic
Rep:91
tmerritt530 will become famous soon enough
Originally Posted by randallman View Post
Furthermore, my dealer continues to claim that the factory solution is not available for my truck yet... While I could install the unit and bezel myself very easily, I'd like to have the EVIC flashed; I guess I need to call around to various dealers to see which one would do it for me I know I have both wiring harness connectors, so it should just plug right in.
As for the prodigy.... I can see many shin bashing events (think peter griffin in family guy) in the future if I were to mount it within an arm's reach of my driver's seat slung under the dash... I'm not even sure the slope of the dash conforms with the installation level requirements of the P2... Perhaps I should RTFM.
Yeah a few if your seat is too far forward.
The original red display prodigy can be mounted up to 70 degrees off horizontal, the blue display P2 can be mounted at any angle, even upside down, so long as it is in line with the longitudingal axis of the truck.
2004 SLT RCSB 4.7L | 3.92 | OEM Off-Road wheels | Goodyear SilentArmor 285/70R17's | dumped magnaflow | H/O cams | H/O cyl heads | 10" Rockford Fosgate P1
Old 05-02-2011, 10:10 AM
Rep:91
Original (red screen) Prodigy mounting:
Prodigy P2 (blue screen) mounting:
I put mine here: superb access to unit for on the fly control and emergency access, at the expense of a few knee strikes...
Old 05-02-2011, 01:48 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
I am 6'2" and I don't bash my shin. I have a manual seat, but it still has room, maybe 2-3 clicks I could move it back. Like Tmerritt said, you can mount it any way vertical, as long as the horizontal is level. I opted to put it over to the right of the steering wheel, because if I put it where he has his, I would bang it every time I got in or out of the truck.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 05-02-2011, 10:23 PM
Yeah... I'm 5' 6" and I keep the seat pretty forward :-) Being short has its advantages... or not
--Randall
Old 05-11-2011, 03:53 PM
rainhater1 rainhater1 is offline
Vehicle: 2010 ram 1500 4x4 06 300 srt8
Trim Level: slt - big horn
Color: light graystone
Rep:116
rainhater1 will become famous soon enoughrainhater1 will become famous soon enough
Default prodgy
Sorry I have been on a trip this is like the other post later on. out of the way and have never hit it. I use the slip in mount as I move it back and forth between the coach and the truck. no screws, just unplug the wires and move it.
Old 05-18-2011, 11:03 AM
pauliwalnutz pauliwalnutz is offline
pauliwalnutz is on a distinguished road
I had a Prodigy P2 in my 2006 Avalanche. Smoothest brake controller ever. I now have the factory brake controller in my RAM and it is not as good as the Prodigy was.
Old 05-31-2011, 05:41 PM
flewellg's Avatar
flewellg flewellg is offline
Vehicle: 2010 Dodge Ram 2500 Laramie
flewellg is on a distinguished road
I have a 2010 Ram 2500 Laramie Diesel with integrated brake controller. Cannot make it work with brake peddle - will work trailer brakes with slide on controller fine. Brakes in trailer are Electric Over Hydraulic-- anyone else having issue with Electric Over hyraulic ?
Old 06-02-2011, 02:25 PM
Wildcat's Avatar
Rep:166
I am pretty sure that the ITBC from the factory will not work with the Electric over Hydraulic, only electromagnetic. Someone please correct me if I am wrong, but that is what I was told.
Old 06-02-2011, 05:04 PM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
I installed a Tekonsha P3, works with elec or Hyd, I chose to place it under my dash all the way over on the left side just touching the foot well trim....I made it fit and look nice by triming the bottom of my emergency brake release handle, to just clear it when pulled....It took quite a bit of time and triming with a dremel, but looks good.....You just have to train yourself to operate the emrgency brake release by just pulling on it's right side, where it isn't trimed...all works great......
So it is written ! So it shall be done!
2010 Ram Factory Trailer Brake Controller Install Netman66 Dodge Ram Knowledge Base 334 04-17-2014 01:51 PM
Installing Factory Brake Controller brc3858 2010 Dodge Ram Forum 17 05-07-2013 08:02 PM
Adding a electric brake controller dave k Electrical 3 08-06-2010 10:36 AM
Installing Tekonsha Brake Controller - No Power mullinon 2010 Dodge Ram Forum 6 07-15-2010 01:04 PM
led third brake light/brake controller pa03hemi Custom Dodge Ram Interior and Exterior Lighting 3 05-20-2010 03:26 PM
