Old 04-28-2011, 01:55 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Post P0303 & P1281 Misfire cyl.3 & Engine running to cold
Well guys and gals just wanted to post what was going on with my truck after porting my intake and heads on this thread=http://www.ramforumz.com/showthread.php?t=80084
Yesterday I noticed my truck running a bit.. I dunno how to explain it but Ill say its running with less performance, MPG's went down and exhaust smell like its burning freaking rich.
Today I noticed the check engine light pop up . I kinda expected it. So I pull the spark plug on cyl.3 and after unpluging the spark plug wire I noticed a small puddle of motor oil build up on the spark plug. I pulled it cleaned it up and reinstalled. I reset the computer, started it up and took it for a drive. It felt alot better after driving 40 plus miles. Im assuming it cycled a few times and engine light would of poped up by now. Im curious how the hell that oil got there and will it happen again? Should I prepare myself for something bigger to happen hahaha damit. Oh yeah whats up with that P1281 pd code "eng running cold". Has anyone had this similar problems? Im searching through threads but maybe im not looking in the right ones
Thanks ya'll for reading. Ill keep ya'll posted on my future findings and results.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 04-28-2011, 08:23 AM
jbryan2's Avatar
jbryan2 jbryan2 is offline
Vehicle: 2001 Dodge Ram 1500 4x4
Trim Level: 4x4
jbryan2 is on a distinguished road
Not 100 percent sure about the oil situation but I can tell you the trouble code p1281 is 99 percent of the time a thermostat problem. I had this issue with my 5.9 last year about this time. Installed new one and was good to go
Old 04-28-2011, 12:21 PM
RAMING IT's Avatar
Rep:65
Cool Tstat.
Good to go BRYAN! I should of replaced that muther when I had her out. Im going to my docs appt 29 miles away. We'll see how she performs. Im also buying some new plugs.
Old 04-29-2011, 12:18 AM
RAMING IT's Avatar
Rep:65
Well after inspecting the engine i've concluded that it might be a valve stem seal, or maybe some kind of debri not letting a valve close.
Old 04-29-2011, 12:51 AM
jbryan2's Avatar
Trim Level: 4x4
Just out of curiousity what was the cost associated with porting the heads and did you really notice a big difference or more work than its worth
Old 04-29-2011, 01:05 AM
RAMING IT's Avatar
Rep:65
Gaskets and all the misc. things was about 160 ish. Give or take. I did all my the work myself so no cost in labor. At the present time im feeling more work than its worth but honestly I know when I square away all these smaller issues Ill feel it was worth it. Plus this mod ties in with all my future upcoming mods so when its all said and done... It'll definetly be worth all these headaches HOORAH!
Old 04-29-2011, 10:20 PM
RAMING IT's Avatar
Rep:65
Default Leaky Valve Covers
So guess what I found out today... To my suprise the oil was leaking from my valve covers. The RTV wasent holding up so im replacing them with gaskets. Thank god I thought it was somthing major.
Old 05-02-2011, 06:14 AM
RAMING IT's Avatar
Rep:65
Look at this nonsense hahaha.
Old 05-12-2011, 11:10 PM
jbryan2's Avatar
Trim Level: 4x4
Was all the work worth it as far as performance and what else are you planning on doing?
Old 05-13-2011, 02:17 AM
RAMING IT's Avatar
Rep:65
Thats the Million dollar question and after driving it for about a month I feel it was worth it not just because of the performance but because I have been wanting to do this mod & a couple of others ones for a few years now, and after successfully pully this off alone from day one (well not really alone the Z helped out too) it has given me a hell of alot more confidence and jbryan that right there bud is priceless
But back to performance yes bud It helped pick that 6600 lbs beast up! That alone is an acomplishment hahaha. Well my other future mods (wish list) are as follows:
1 Going back to stock tires 275/55/20 maybe 285/50/20 I loved how they handled! Currently using 275/60/20
2 Remove 2.5" leveling kit
3 Blisteen shocks all around
4 Crossed drilled rotors all around
5 Hooker longtube headers
6 True duel 3" exhaust , xpipe w/ dual series 10 flowmasters dumped
7 UD pulleys
8 Electric Fan & Water pump with HD alternator(not sure yet)
9 Comp Cams 270 Magnum hyd. flat tappet cam kit pt# K20-214-4 dont wana go to go to crazy right now.
10 Edlebrock Air Gap Intake
11 MSD ign. 8mm wires
12 Looking to getting it all tuned by hemifever
cyl 3, misfire, running cold
engine too cold too long Quiet Lunatic 5.9L V8 Specific Topics 11 02-11-2014 09:52 AM
engine clicking noise on cold starts John999 Dodge Ram General Discussion 9 01-07-2011 05:06 AM
Engine Ticking Sound In Cold Temperatures RamTech Dodge Ram Recalls and TSB's. 19 09-05-2010 04:58 PM
2000 Dodge Ram 1500 Engine Idle up and down on cold start Quiet Lunatic 5.2L V8 Specific Topics 4 01-15-2010 07:30 PM
Cold Engine knock 95 ram 5.2 liter kccoln 5.2L V8 Specific Topics 3 02-17-2009 06:03 PM
