loud air noise - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Body & Interior
Old 04-28-2011, 12:36 PM
DerekWagen DerekWagen is offline
Vehicle: 2004 Dodge Ram
Color: Champain/Tan
Rep:47
DerekWagen is on a distinguished road
Default loud air noise
I drive over 500 miles a week between Houston, San Antonio, and Austin the past few days my passanger door has been letting air flow into the cab not enough to feel but if you grab the black window seal from inside and pull it in, it stops just wondering if any of you guys out there have had this problem and of so how did you go about fixing it I cleaned out the cab vents thinking they had dirt in them and that was wrong and now I'm thinking the door seals need to be relaced?
Old 04-28-2011, 12:46 PM
Vehicle: N/A
Rep:1045
might not have been you, but my wife (typical) locked her keys in the 300c, and the cops so kindly unlocked the door using a inflatable wedge in the door. ever since then, she has the same loud noise at highway speeds. its either the seal, or the door is slightly 'bent'
Old 04-28-2011, 03:03 PM
CA.RedHemi's Avatar
CA.RedHemi CA.RedHemi is offline
Vehicle: 2004 Dodge Ram 1500
Rep:13
CA.RedHemi is on a distinguished road
04s have a problem with door seals or I should say the design of the door to seal. If you look at the corner by the side mirror you should see where the door from opening and closeing tears up the seal. I had a set replaced by the dealer in the first year I had my truck. They did adjust the door as much as they could but the corner of the door still rubs the seal and now I'm ready to put on my 2nd set of seals.
Old 04-28-2011, 03:17 PM
When this starts to happen it's usually because the door seals have dried out, or cracked and flattened; causing a wind leak. That you pulled on it and it stopped tells me that your seals need to be replaced.
Loud bang noise davillepits Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 6 04-18-2011 01:29 PM
loud thumping noise and broken A/C at startup! 2009hemi5.7 5.7L (345 cu in) HEMI V8 Specific Topics 2 01-12-2011 05:25 PM
4X4 not working along with loud clanging noise LP011107 5.9L V8 Specific Topics 7 01-09-2011 04:46 PM
Loud Noise WesGee 2009 Dodge Ram Forum 8 09-16-2010 07:38 PM
rubbing, loud squeeling noise gb2525 5.7L V8 Specific Topics 5 05-29-2010 07:48 AM
