Old 05-18-2011, 10:07 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I agree with charlieb. Start with the trans in neutral. When first put into gear, it is normal for the drivers side of the engine to raise from the torque.....but not to much, and it should not make any noise when doing this. Applying a small amount of throttle will increase the torque, which will exaggerate this engine rise a bit.
Also look for items around the exhaust manifold that could be rubbing, as well as suspension components in the area of the motor mount.
Good Luck.
brad
Interested in one of my mods?
Old 05-25-2011, 10:33 PM
ntjacks23 ntjacks23 is offline
Vehicle: 2001 Dodge Ram 1500 4X4
ntjacks23 is on a distinguished road
should there be any play on engine or tranny mounts? just trying to find out what im looking for exactly while doing it
Old 05-31-2011, 11:44 PM
correct and correct. only when in gear and either rocking the truck or jumping on the board. If you grab the front drive shaft and shake it you can hear it a little as for the rear drive shaft i would assume too. aiming towards mounts? what do I look for while checking mounts?
Old 06-01-2011, 01:32 AM
brad12kx's Avatar
Rep:2581
It could be a loose thru-bolt on the front mount(s), or the restriction pads....or the mount itself. They use a type of rubber as an isolator/cushion, and this can deteriorate and cause squeaking. After checking the thru-bolt of integrity, you could spray a water/dish soap mix on the mount to temporarily lubricate it for the purpose of determining whether or not it's squeaking. The mounts can be replaced with the engine in place, but you will have to lift it up about 2-3" to clear the bracket on the frame. If you discover it's the mount and do decide to replace them, do one at a time to minimize the clearance issues from lifting the engine.
Also, check the mount at the rear of the transmission. Check for loose bolts.
brad
squeek b gone jdRAM88 2010 Dodge Ram Forum 5 12-04-2010 01:18 AM
Please excuse me bones64 Off Topic Discussion 126 10-10-2010 12:15 AM
Brake peddle squeek? UnLiMiTeD 2010 Dodge Ram Forum 26 10-05-2010 01:35 PM
Squeek in passenger seat 0007 Body & Interior 4 09-16-2010 09:59 PM
Terrible Gas Mileage dmh7891 5.9L V8 Specific Topics 7 06-10-2010 02:48 PM
