Old 04-28-2011, 10:06 PM
Ram Tough's Avatar
Ram Tough Ram Tough is offline
Vehicle: 1999 Dodge Ram 1500 Sport 4x4
Color: Primer Gray
Ram Tough is on a distinguished road
Default 46re problems FIXED......
46RE PROBLEMS FIXED....
DTC code p1765(trans 12volt supply relay control circuit)....FIXED which is the relay in the power distribution under the hood...
Overdrive shifting problems fixed with new overdrive unit, TCC / OVERDRIVE solenoids assembly, governor pressure switch, and governor pressure solenoid...
Problem with Park-Reverse-Neutral... truck goes forward when selecting any one of those gears will be fixed tomorrow when I remove the valve body and clean it. Also by replacing check ball #8 which blocks line pressure from entering the rear (Forward) clutch circuit when selector lever is placed in Park, Reverse or Neutral......
Sorry no pics don't have anyway to take them.....
Old 04-28-2011, 11:27 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Sounds like your making progress. Got a cell phone? Doesn't it have a camera? Sure would like yo see what you're getting done.
Old 04-30-2011, 03:28 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Where did you get it scanned and how much did it cost?
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
leveling kit problems? jaybull Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 10-27-2014 11:32 AM
2 problems: diagnosed and fixed Mikel Electrical 8 05-16-2012 09:17 PM
Transmission Problems cudase 5.7L (345 cu in) HEMI V8 Specific Topics 30 01-19-2012 02:50 PM
'09 Problems fixed in '10? Wildcat 2010 Dodge Ram Forum 2 08-30-2010 10:16 PM
46re problems aroising 5.9L V8 Specific Topics 2 12-17-2009 03:34 PM
