Old 04-29-2011, 01:25 AM
P Rod's Avatar
P Rod P Rod is offline
Vehicle: 2011 Ram 2wd Crew Cab
P Rod is on a distinguished road
Default Opinion needed on 3.92 gears
So I have a narrowed my search down to two different Crew Cab Sports. Both well equiped. One a little more than the other (back up cam and sun roof) two different dealers for approx the same price. the one with better equipment has 3.92 gears. As about 70 percent of my driving will be hwy miles, do you think it will hurt the already poor MPG? By the way I will not be doing much towing and no drag racing.lol Thanks
CrewCab Sport*Sunroof* Navi*3.92's*Ground Force 2/3 drop*Back Flip F1*Mufflex 18"*BedTred
Old 04-29-2011, 01:28 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
I have the 3.55's and wish I had the 3.92's for the limited slip differential. There are many unhappy 3.55 owners just for that reason. If I had it to do again I'd go for the 3.92's and never look back.
Old 04-29-2011, 01:34 AM
Rep:2705
jump on the Ram with the 3.92 rear end, it can do more & your MPG is slightly different, not enough to really matter unless you drive a few thousand miles a week
Old 04-29-2011, 04:03 AM
StoneyWV StoneyWV is offline
Vehicle: 2010 Ram Quad Cab 4X4
Rep:27
StoneyWV is on a distinguished road
My 2010 has 3.55 gears and I get better mgp with the MDS off on the highway at 65-70 mph. The 3.55 gears are too low for the wind resistance and weight of the truck. It is in and out of gears constantly, every time gust hits the front of the truck. I'm still astonished how the 3.55 gears made it into production. I've also got the ST model which has the smallest tires of them all, so can't imagine what it's going to be like when I replace the factory rubber with 33" tires. Guess it still works good for when you are coming out of the mountains on a descent that takes a few miles.
2010 QC ST, 5.7L, 4.10 Gear Swap, 5100 Leveling Shocks at 1.7", K&N Drop-in, Pioneer U310BT, 2/12" DC Level 3/Net Audio Sub Box, JL Components, ARC Audio Amps, Flowmaster American Thunder duals, Granite Alloys sporting 34" Falken Wildpeaks, HID conversion full blackout.
Old 04-29-2011, 09:52 AM
dafoot dafoot is offline
Vehicle: 2011 Dodge Ram, 1500, Hemi
Rep:16
dafoot is on a distinguished road
I traded in my 2010 with 3:55s for a 2011 with 3:92s. Nuff said!!!
DAFOOT
Old 04-29-2011, 11:21 AM
dwadestrick's Avatar
dwadestrick dwadestrick is offline
Vehicle: 2011 Ram Crew Cab 4x4
Color: Deep Water Blue Pearl
Rep:85
dwadestrick will become famous soon enough
Send a message via Skype™ to dwadestrick
Simple: 3.92. Unless you are looking for every mpg you can find.
Factory:
Break controller, Mopar Chrome Tubular Side Steps, Sprayed in bed liner.
Changed:
Bak Flip F1, Performance Hood, Remote start
Old 04-29-2011, 11:40 AM
Trim Level: sport
Color: green
Rep:677
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i've always had trucks with limited slip. bought my truck in jan and even with some of the heavy snow storms, ice storms and rain i didn't miss it. between the limited slip that is standard, and the new all wheel drive feature, i'm not not sure if it is really needed anymore unless you are getting a 2 wheel drive truck. i live in the very northern part of very hilly new jersey and find the 3.55 work well for me. this ratio has also been fine on the hwy. if ever get a heavy toy and start towing it, rather than getting a new truck, i'll just regear to 4:10 or higher. i think you'll be fine with the 3:55. best thing to do is take a good ride in both trucks, not just the usual 15 min test drive. try an test in on your daily commute roads and then go back and drive the other the same way.
Old 04-29-2011, 11:44 AM
Trim Level: sport
Color: green
Rep:677
i also wonder about the 3:55 and 3:92 ratios. wonder why dodge doesn't replace with 3:73 and 4:10 ratios. for me 3.73 would be perfect. this is what i had in 2500 and 3500 diesels. not worth it for me to change out 3:55 to 3:73 though.
Old 04-29-2011, 11:49 AM
rinkerman rinkerman is offline
Vehicle: 2010 Crew Cab
rinkerman is on a distinguished road
By 2002 Ram with 2 wheel drive has a 3:73 limited slip & it is great even with only the 4.7 motor. Agree with the others that are disappointed with the 3.55 gear. If could do it over my 2010 would not be a 3.55. Live & learn
Jump on the 3.92 gear - my next one will have it.
Old 04-29-2011, 03:02 PM
jc4041's Avatar
jc4041 jc4041 is offline
Vehicle: 2009 QC 4wd
Rep:146
jc4041 will become famous soon enoughjc4041 will become famous soon enough
my ST has the 3.55's...will be going to 4.10's within the month. currently running 275/70/18...33x11's pretty much the 3.55's do ok, still plenty of get up and go, but most of my driving is on base/city so the 4.10's will help out a lot better
Ram DSP, CAI, Cherry Bomb Extreme, AirLift 1000
'07 Dodge Charger SRT8 SuperBee #579-CAI, DSP, dual Cherry Bomb Extremes
'07 GCSRT Stock
3.92 gears or 3.55 gears? Skeeter43 2010 Dodge Ram Forum 59 04-09-2011 10:24 PM
are gears needed for a 9" lift??? 08ramKING Dodge Ram 4x4 - Offroad Discussion 13 04-09-2011 04:18 PM
3.55 or 3.92 gears? HEMIHP 5.7L (345 cu in) HEMI V8 Specific Topics 11 02-15-2011 02:04 AM
3.55 or 3.92 Gears? Want 35's and lift.. LUCK Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 20 12-15-2010 06:12 PM
Question for owners with 3.92 gears. Simcik 5.7L (345 cu in) HEMI V8 Specific Topics 9 11-18-2010 03:47 PM
