Old 04-29-2011, 01:59 PM
gabassman gabassman is offline
Vehicle: 2000 Dodge Ram 1500
gabassman is on a distinguished road
Default Keyless Entry
I just picked up a 2000 Dodge Ram 1500 Quad cab and the dealer gave me a keyless remote but I need to program it. I went to a nearby Dodge dealer and they wanted $35 to do it. Can anyone help me program it?
Old 04-29-2011, 04:13 PM
Rep:2640
Welcome to this RamforumZ from San Diego
i am not sure, but i believe only a Certified Locksmith or the Dealer can program it
$35 is actually quite cheap from a dealership
Old 04-29-2011, 09:26 PM
I looked online and found several places that will send you the codes for $7 plus shipping, was wondering if they are legit.
Old 05-02-2011, 09:16 AM
timothy1's Avatar
timothy1 timothy1 is offline
Vehicle: 1997 Dodge Ram 1500
Color: SILVER
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
timothy1 is on a distinguished road
Take it to the dealer and pay the money... It is worth it! My mits cost $75
Technology is good until it turns on you!
Old 06-19-2011, 01:24 AM
FrankTank FrankTank is offline
Trim Level: Laramie SLT
Color: Blue/Silver
FrankTank is on a distinguished road
Try these instructions from ProgramYourRemote for a 2000 Ram
ATTENTION: You MUST HAVE one working remote to add one more to the system. If you do not have one working remote right now then these instructions will not work. You will have to have a Locksmith or dealership use a computer to program the first remote for you.
Click here to find a Locksmith in your area to program this remote.
1. Turn ignition to run position (as far as you can go without starting engine).
2. Using any Working remote, press the UNLOCK button for 4 to 10 seconds.
3. Within the specified 4 to 10 seconds, continue pressing the UNLOCK buton and press
the PANIC button for 1 second and release both buttons at the same time. A chime will
sound within 3 seconds to indicate that the vehicle has entered remote programming
mode.
4. Within 30 seconds of the chime, press any button on all remotes to be programmed
including previously programmed remotes. A chime will sound after each remote is
programmed.
5. Turn ignition to OFF and remove key.
6. Test all remotes.
Good luck and let us know if this works!
Keyless Entry? Rogers Rams 2010 Dodge Ram Forum 28 02-01-2011 08:44 PM
OEM Remote Keyless Entry for 2007 Ram 1500? MayoBoy Dodge Ram General Discussion 10 08-05-2010 12:23 PM
98 Ram Keyless Entry (3/4 of the way there) strang3majik Electrical 6 06-19-2010 09:04 AM
2004 Durango Keyless Entry Doesn't Work TenneSST Other Vehicle Discussion 4 02-28-2010 05:49 PM
Factory keyless entry question sherfield2002 Dodge Ram General Discussion 16 12-01-2009 10:28 PM
