Old 04-30-2011, 09:37 PM
bam2880's Avatar
bam2880 bam2880 is offline
Vehicle: 2013 dodge ram
bam2880 is on a distinguished road
Default 4.7 coolant loss
i have a 2005 dodge ram 1500 with the 4.7 motor with 68000 miles and i seem to be losing coolant but i cant find any leaks anywhere or anything and i dont really have any signs of a bad head gasket does anyone know what it could be
Old 05-01-2011, 12:09 AM
I'd pressure test your coolant system. Don't forget the cap. You could be losing a small amount of coolant every minute as steam getting past the cap or a pinhole leak in a hose that only opens up under pressure.
Old 05-14-2011, 12:48 AM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
x2 on the cap. Also pay special attention to the areas surrounding the water pump. The gaskets on the water pumps in these engines are also known to fail.
Also, just because evidence of a H/G leak isnt manifesting itself doesnt mean it isnt there. A pressure test will take you to your problem no matter how big or small.
Sure it'll suck, but it'll make you a man
Old 04-11-2013, 06:05 PM
WhyteCheddar WhyteCheddar is offline
Vehicle: 2002 Dodge Ram
WhyteCheddar is on a distinguished road
I'm going to piggy back on this thread rather than start a new one.
I seem to be losing some coolant via the breather tube on my over flow tank. Its a small diameter rubber tube attached to the filler neck on the over flow tank. It drips down the side of the over flow tank and to the ground. Some of the excess seems to collect on the fan shroud and drips down from there. Its not a lot but still seems unusual to me.
The temp gauge is solidly in the normal range and the engine runs perfectly. No over heating smells or other leaks. 172k miles on this 4.7. Its clean as a whistle otherwise.
Thoughts?
Old 04-11-2013, 06:42 PM
ff605gag ff605gag is offline
ff605gag is on a distinguished road
I had the same problem with losing coolant and couldn't find where it was going. Turned out that there were some small flaws in the heads got that fixed no more coolant lost. Now if I can just figure out why it wont idle right.
VA Benefits and State Benefits for Vets RootBeer Military 1 11-04-2010 04:16 PM
Coolant loss in 1999 Dodge Diesel 3500 dually kebro004 Cummins Diesel Specific Topics 3 07-13-2010 11:19 PM
mysterious coolant loss and jumpy oil pressure guage joshockey 5.2L V8 Specific Topics 9 06-25-2010 12:29 AM
Coolant leak. Bad rad? bigdaddyII 4.7L PowerTech V8 Specific Topics 17 12-16-2009 07:26 PM
