Old 04-17-2011, 07:48 AM
adventurer's Avatar
adventurer adventurer is offline
Vehicle: 2010 Ram and 2006 Ram Hemi
Trim Level: 4x4 SLT and4X4 SPORT
Color: Silver , Flame Red
adventurer is on a distinguished road
Send a message via Skype™ to adventurer
Default AC Problem.......
Hi all , i have a problem with my AC in my 2006 Ram ,last month i filled the AC gas and they compressed it before filling the gas to see if its leaking and they found no leak so i tried it after that it was working perfect with cold air , today the weather is hot so i switched the AC on but it was blowing normal air i waited 10 minutes thinking it will blow cold air but i waited for nothing it continues blowing hot air , fan is working compressor is working the AC light is on and there is no gas leak !!!!!! Any ideas please ???
2010- S&B CAI/87MM TB/HKS TB GW/OIL FILTER BREATHER/Y PIPE/PYPES VIOLATOR MUFFLER/HEMIFEVER TUNE.
06- MAGNAFLOW CAT-BACK/Y PIPE/TB SPACER/HKS-TB GW/MOPAR CAI/SUPERCHIPS/OIL BREATHER FILTER/JET 180 TSTAT/3.92 LSD
Old 04-17-2011, 09:58 AM
tmerritt530's Avatar
tmerritt530 tmerritt530 is offline
Vehicle: 2004 Ram 1500 4.7L "H/O"
Color: Graphite Metallic
Rep:91
tmerritt530 will become famous soon enough
Maybe the blend door isn't working? Does it blow hot air or just outside temp air?
2004 SLT RCSB 4.7L | 3.92 | OEM Off-Road wheels | Goodyear SilentArmor 285/70R17's | dumped magnaflow | H/O cams | H/O cyl heads | 10" Rockford Fosgate P1
Old 04-17-2011, 10:34 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Sure the compressor is running, i.e. the centre part is turning as well and not just the pulley ????? If it is does the suction line (large tube coming off the compressor) get cold ?
Old 04-17-2011, 12:54 PM
adventurer's Avatar
i just came from the work shop , there was no gas in the system they checked everything there was no leak and everything is ok but while they were compressing the system the hose blown up (the one in between the gas filler place and the compressor ) then they say that the hose were leaking but its not true because it was ok when they start the compression check, so they replaced the hose and filled it with gas again and they say the system is ok , am not sure that this was the problem , any way i will test it tomorrow and see, Any ideas ???
Transmission Problem 07 Hemi 07Ram 5.7L V8 Specific Topics 14 03-14-2013 06:45 PM
First Dodge - First Ram - First Post - First Problem koolaidzx2 Newbie Checkin! 11 01-17-2011 12:10 AM
Headlight problem oscart47 Electrical 3 12-07-2010 11:48 PM
Door Ajar Light & Power Windows Problem. scottdutton Electrical 1 12-05-2010 04:54 PM
Yet another HID problem griffin407c Custom Dodge Ram Interior and Exterior Lighting 10 10-27-2009 04:37 PM
