Old 05-01-2011, 09:10 AM
jason4321 jason4321 is offline
Vehicle: 94 dodge ram
jason4321 is on a distinguished road
Default 94 ram no start
Hey everyone I have a 94 RAM with a 5.9 and it won't start.
I had a loud hissing noise coming from the iac before it stopped running so i replaced the iac and now it won't start I have spark and fuel pressure at the rail. Any ideas?
Old 05-01-2011, 11:50 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
Pull the TB off and clean it throughly.
Old 05-01-2011, 12:20 PM
Throttle body is brand new. Also replaced tb gasket and intake gasket and plum gaskets not.t long ago
Old 05-01-2011, 12:22 PM
panhead's Avatar
Trim Level: WS
Rep:103
Where did you get the IAC?
Old 05-01-2011, 12:24 PM
Autozone, but would that keep the engine from starting?
Old 05-01-2011, 12:27 PM
panhead's Avatar
Trim Level: WS
Rep:103
Eh, well they don't really make the best parts.
Old 05-01-2011, 02:31 PM
Anyone else have any ideaa?
Old 05-07-2011, 11:16 AM
mAs mAs is offline
Vehicle: 1994 Dodge Ram 1500 2WD
Trim Level: Laramie SLT
Color: Jet Black
Rep:36
mAs is on a distinguished road
I know for fact a ram will NOT start with an unplugged crank sensor. When I swapped trannys a while back I forgot to plug mine back in and when I went to start er up it was like... seriously WTF... "OOPS". The wires are sorta close to each other back there so ya never know. The crank sensor is the one that is a super PITA to get at on the passenger side bell housing by the trans dip stick. The wire should be a good 12-18" long tho to go to the connector on the harness.
I don't think a bad IAC would keep the vehicle from starting as long as u put a little gas into it while you crank it over, the IAC is there to bypass the throttle plate via computer control to let more or less air in. So your foot can accomplish the same thing on start. A bad IAC will cause it to run like ass though. But she should still fire. Of course its a bit more complicated than that... but that's basically all it does. Someone correct me if i am wrong but i HAVE started my ram with the sensor unplugged a few times while trouble shooting so...
Old 05-07-2011, 04:44 PM
I replaced my coolant sensor because it was dumping fuel due to the connector being broken, all my plugs were soaked in gas, so I replaced all the plugs, and I still can't get the truck to start. Only time it even attempts to start is when the throttle is completely open. I can actually get it to run for a minute if I unplug the fuel pump relay and spray throttle body cleaner into it. any ideas?
Old 05-08-2011, 12:02 AM
panhead's Avatar
Trim Level: WS
Rep:103
Do you have any codes?
Darn thing won't start --> clicking noise under dash david05111 5.2L V8 Specific Topics 3 05-01-2011 08:48 PM
Remote start tip snyds 2011 Dodge Ram Forum 3 03-16-2011 09:23 PM
Remote start does not work with low fuel sportcrewMI 2010 Dodge Ram Forum 10 11-22-2010 11:18 PM
new truck at 50 miles and wont start rich1500 2010 Dodge Ram Forum 11 08-05-2010 09:48 PM
2010 doesnt always start after remote start bigdadsram Electrical 1 12-15-2009 09:27 PM
