Place your Ad Here!
Old 05-01-2011, 11:32 AM
hylander hylander is offline
Vehicle: Dodge Ram
hylander is on a distinguished road
Default Not firing on #8 Cylinder ?
98 5.9
CEL comes on and off, codes says not firing on #8
Could this be anything serious ?
Truck seems to run normal
Old 05-01-2011, 11:45 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
When was your last tune up?
Old 05-01-2011, 11:52 AM
Vehicle: Dodge Ram
No idea, this is a truck I am considering buying.
Seller says he thinks it may need plug wires, cap and rotor, says it has new plugs
Old 05-01-2011, 12:15 PM
panhead's Avatar
Rep:103
Before you buy it, do a compression test. If all the cylinders are good, could be a bad injector or wires, cap and rotor.
Old 05-01-2011, 12:25 PM
Vehicle: Dodge Ram
Thanks
Will see if he will let me do a compression check
Old 05-07-2011, 10:38 AM
Reverend Son's Avatar
Reverend Son Reverend Son is offline
Vehicle: 2001 dodge ram 1500mag 5.9 4x4
Color: RED.
Reverend Son is on a distinguished road
My truck has the same problem. My #3s been misfiring.
Got the plugs, cap, wires, and rotors replaced.
Truck ran without the engine light on for a few weeks, now its turning on and off randomly again.
Truck has been running fine though.
I was told it'll be a good 1000$$$ fix.
2001 1500 magnum(5.9).
Old 05-07-2011, 11:02 AM
mAs mAs is offline
Vehicle: 1994 Dodge Ram 1500 2WD
Trim Level: Laramie SLT
Color: Jet Black
Rep:36
mAs is on a distinguished road
I agree compression check, heads on these trucks are known for cracking between valves. Beyond that, you could have a leaky injector dumping too much fuel, or clogged or failing injector that does not deliver enough fuel. You can just put a long screw driver against the #8 injector and hold it to your ear and at least hear if it is ticking away quickly like it should. Thats not a true test though, but it will tell you if it is at least alive. Only an oscilloscope can check an injector pulse properly. Or of course an expensive dealer scanner.
As far as simple fixes though, what would be nice is if it was as simple as the #8 wire is bad, or a point on the distro cap has worn out enough it cant spark from the rotor to the point on #8 any longer. Or theres no tip left on spark plug #8 but you say the owner says it has new plugs so.... Do you have a spark plug wire tester? They look like a pen, and have a little window in the side of them... you hold it to the spark plug wire while the vehicles running and the little window in the side of it will flash with the spark plug wire pulses. Mines made by champion they are like 10bux. That would be the easy way to narrow out distributor/rotor. Could only be plug, injector, or cracked head then.
Old 05-07-2011, 12:16 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Originally Posted by hylander View Post
Thanks
If he won't.....RUN!
brad
Interested in one of my mods?
Old 05-07-2011, 02:49 PM
Ram98's Avatar
Ram98 Ram98 is offline
Vehicle: '98 Ram 1500 , 2004 Rumble Bee
Trim Level: Sport,Rumble Bee
Color: Blue, Yellow
Rep:28
Ram98 is on a distinguished road
Another thing to check is the plenum gasket. The 5.9 is know for blowing it and it a lot of times it shows up as a misfire in the #8 cylinder. The way to check is to look down the throttle body and see if theres any oil. There are several forums on it in here if you go through search.
98 Ram 1500 Sport 4x4 5.9L
2004 Ram 1500 4x4 Rumble Bee
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 07:45 AM
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
Cylinder 5 misfire, and now cylinder 8 and a random misfire... suggestions? itsaRAMthing 5.9L V8 Specific Topics 5 06-05-2011 07:35 AM
Altering Plug Wires Basher Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 12 03-02-2011 12:06 PM
Tuners and 4 cylinder/ 8 cylinder adjustments? Aviator23 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 12 12-26-2010 01:13 AM
