Old 05-01-2011, 02:16 PM
SPARTACUS's Avatar
SPARTACUS SPARTACUS is offline
SPARTACUS is on a distinguished road
Default clicking in left front wheel well area
I have a clicking sound in the left front tire area, I inspected the tire and wheel well area and saw nothing out of the ordinary. the sound increases peed as the truck goes faster. Any thoughts?
Old 05-01-2011, 02:22 PM
Two things come to mind....a wheel bearing or a broken belt in the tire.
Old 05-01-2011, 02:25 PM
SPARTACUS's Avatar
ya think? I dont even have 10000 miles on the truck! It sounds like a baseball card in the spoke of a bicycle. its anoying.
Old 05-01-2011, 02:31 PM
Aries's Avatar
Aries Aries is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Aries is on a distinguished road
A rock stuck inside your tires treads.
Old 05-01-2011, 02:32 PM
Yeah, it could be a rock too.
Tires can be defective even if new. Bearings can have defects as well. 1000 miles doesn't mean it's wore out, just possibly defective.
Old 05-01-2011, 02:34 PM
SPARTACUS's Avatar
i removed all rocks from the tire, I even had someone drive it for me so I can listen to it, the noise is coming from the wheel well area, but everything looks fine. still looks brand new.
Old 05-01-2011, 02:39 PM
Honest, looks can be deceiving. A bearing or tire belt really can't be seen.
Here's something you can try. Jack up the front end and rotate the tire. See if it clicks. If not, you can rule out the bearing.
Old 05-01-2011, 02:42 PM
SPARTACUS's Avatar
I'll give it a try. thanks
Old 05-01-2011, 04:41 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
while you have it jacked up grab the tire on top and bottom and see if there is any play. then grap it on the left and right side and see if there is any play.
here is a video.
here is a link to symptons
http://www.ehow.com/about_5072684_sy...-bearings.html
Old 05-01-2011, 05:49 PM
SPARTACUS's Avatar
found the problem, pulled the tire off and a stick was jammed down behind the rotor. couldnt see it with the tire on. Lucked out! Thanks for the info Gents.
2006 vibration 55mph rake1 Suspension 41 03-07-2014 08:52 PM
instructions to enable front seat video in motion partypooper 2010 Dodge Ram Forum 20 08-05-2011 07:14 PM
Sound from front right wheel area sullivan Suspension 2 04-09-2011 05:34 PM
Clicking/Leaking Front End?! jtsharps Suspension 8 03-22-2010 11:06 PM
Front Wheel U Joint Rattle Morker1 Suspension 2 09-23-2009 10:09 PM
