Old 05-01-2011, 01:28 PM
015.2Ram 015.2Ram is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: XLT
015.2Ram is on a distinguished road
Default 01 Ram - 5.2 motor, trans sounds odd!
Had the truck for about 2 months now. 5.2 motor, 93k, runs great. Trans shifts fine, seems there is no issue with it. Since having it there have been a 2 or 3 times when put in reverse on a cold start the trans has a whining sound like the PS unit is going out. But the sound is coming from the trans in the rev gear only when cold. Never does it when it is warm and most of the time does not do it at all cold or hot. When it does it it still works properly just makes the noise. Is there a pump in the trans that may be going out or jsut does not like cold? Last I looked the fluids in it were ok? Trans pan need a drop and new filter maybe?
Old 05-01-2011, 01:53 PM
I'd suspect either the trans pump or the torque converter is making the noise. Mine did when it was cold, too. I just got used to letting it warm up a bit. Nothing ever happened with the trans and it worked just fine.
Water Sloshing In Dash (Sounds Like) 98RamSport Heating & Cooling 12 11-08-2011 07:38 PM
Standard drive sounds killah! BIG KON Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 1 03-16-2011 05:04 PM
Truck bogs down bad/ sounds like a huge vacuum leak sbrucher 5.9L V8 Specific Topics 4 12-24-2010 01:26 PM
Sounds like a wind storm? RootBeer 5.7L V8 Specific Topics 5 10-16-2010 09:49 PM
CRAZY grinding noise from front end! It sounds like the Apocalypse! redblur Suspension 3 06-23-2009 02:18 PM
