LSD Differential - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 05-02-2011, 10:30 AM
Redlongbed's Avatar
Redlongbed Redlongbed is offline
Vehicle: 2002 Dodge Ram 1500
Redlongbed is on a distinguished road
Default LSD Differential
I was doing a rear differential service on my 02 1500 with the 3.92 LSD rear last weekend and I noticed one of the retaining clips had broken off which seem to be common with the LSD's. My question is what will happen if I don't replace this? Will I just not have a LSD or will it ruin my rear? I removed the clip and the fluid was silvery and I didn't see any metal shavings in there. I plan on replacing all the clips I just don't know how soon I can do it. Also anyone know where to get the clips? Do I have to go through mopar? Thanks.
Old 05-02-2011, 10:31 AM
Redlongbed's Avatar
^^ I meant to say the fluid was not silvery...
Old 05-02-2011, 06:26 PM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2017 ram express quad cab
Trim Level: express
Rep:37
charlieb is on a distinguished road
the clips are important they keep things from moving around and wearing out carrier and other parts.you can still drive it. may last 1 month may last 5 years but then you will need to replace everything not just 20 dollar clips from dodge.you may also need to replace axle seals at same time when you do the clips can be labour intensive.but your lsd(clutch packs) rear will still work as it should until everything gets sloppy and something breaks also what might happen if ur rear locks up at 55 mph on highway?
Old 05-04-2011, 05:20 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Locking up going 55 mph Damn! If that dont scare you enough to replace them ASAP... I dunno what will haha..
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
How to decipher axle codes? BigSwede 2011 Dodge Ram Forum 6 01-07-2011 06:37 AM
Rear Differential messed up bdiomus 5.7L V8 Specific Topics 11 12-29-2010 10:12 AM
Possible differential problem 05 hemi 1500 hydrex 5.7L V8 Specific Topics 0 12-15-2010 12:43 PM
Rear end confusion dirtsurferus Suspension 6 12-30-2009 09:25 AM
Limited slip differential buzzdoyle LD RAM - General Discussion 2 12-19-2008 02:30 PM
