Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 05-02-2011, 12:40 PM
juzrainy63's Avatar
juzrainy63 juzrainy63 is offline
Vehicle: 2001 dodge ram 2500
Color: burgandy
juzrainy63 is on a distinguished road
Default turn signals/hazard lights
while waiting for at a light with my turn signal on, it stops flashing and stays lit, this happened with the hazard lights yesterday also. does anybody know what i need to do to fix the problem? i have checked the bulbs and the fuses
Old 05-02-2011, 03:07 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
What did you find when you checked the bulbs? My feeling based on the solid state, no flash, is a bad bulb on the left side. Have someone sit in the driver's seat and hold down the brake peddle while you look out back to see if all brake lights are burning. Check the left And the right turn signal on the front and rear while the parking lights are on and off. Look to see that you have a brighter flash in the socket and not just a on off when the turn signal is onn. If indeed the bulbs are all good then I'd suspect the flasher, relay is bad.
Old 05-02-2011, 11:20 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I vote for a bad bulb.
brad
Interested in one of my mods?
turn signals
Problems with my turn signal lights. kjtc6 Electrical 20 06-06-2013 08:02 PM
Tail lights go out when I turn on headlights FamilyTradition Electrical 3 11-04-2010 11:12 PM
2007 3500 oem fog lights dont turn on? furious405 Electrical 3 07-31-2010 03:28 PM
Corner Lights Will not Turn Off DJTR Electrical 16 12-02-2009 10:38 PM
Interior lights turn on by themselves Raymc7 Electrical 3 10-07-2009 01:05 AM
