Old 05-02-2011, 07:58 PM
c230k c230k is offline
Vehicle: 1999 Ram 1500 4X4
c230k is on a distinguished road
Question 5-Speed (NV3500) Gear Oil Change
Hello folks,
Can someone provide me with a size for the HEX bolt for the drain and fill plugs on the NV3500 Manual transmission. My local O'Reilli does not stock a hex driver as large as is required.
Also, can anyone confirm the Mopar gear-oil recommended is merely 75-W90(non-synthetic). I am putting in a synthetic 75-W90 which I am assuming will exceed specifications for this tranny.
This unit has 240,000 Miles on it and has provided exceptional service. It still shifts great, but runs hot and feels loose when shifting or engaging the cluch. Not sure the last time gear-oil was replaced. I think it was when transfer-case, u-joints were replaced at about 200K, but about 3-years ago. The truck has also started sucking gas since I noticed the tranny issue.
All suggestions appreciated!!
Old 05-03-2011, 12:33 PM
bluewhale bluewhale is offline
Vehicle: 1997 Dodge Ram 1500
Trim Level: base
Color: blue
bluewhale is on a distinguished road
Both drain and fill plugs on my 97 2wd Nv3500 need a 17mm Allen socket. Not sure about the oil so will let other experts hit that one.
I am also thinking to replace the oil in mine with a synthetic 75W-80 oil put out by BG called Syncro Shift II so will be watching as to the answer provided.
Old 05-06-2011, 08:46 PM
Thanks BlueWhale! I let my fingers do the walking and found the 17mm Allen driver.
Worked like a charm! My transmission and I thank you.
I decided to put a non-synthetic 75-W90 in for the short term. I'm going to drive it through for about 500-miles, then change again and replace with synthetic.
The gear-oil was highly broken-down and dirty. Can anyone suggest a flush product I can run through the tranny to get it as cleaned out as possible. There wasn't much in the way of shavings on the drain-plug magnet, but I'd still feel better getting it well cleaned out.
oil change chrisisbored24 Oil Change 24 05-11-2011 06:43 PM
Found out I have a recall :( SslagleZ28 Dodge Ram Recalls and TSB's. 4 03-21-2011 12:23 AM
Speedometer calibration after gear swap? Red05Ram Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 03-16-2011 11:22 PM
45RFE sensors and rear gear change partymn Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 3 11-28-2010 07:45 AM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 01:00 AM
