Old 05-02-2011, 10:59 PM
M n M M n M is offline
Trim Level: ST 1500 Quad Cab
Rep:79
M n M will become famous soon enough
Default Another LED Mod completed
Been wanting to get this one done for some time. I love my truck but could stand to have a bit more light inside. It gets very dark below the stereo and AC knobs. I've read many posts where LEDs were added and that seemed to be the answer. But I didn't want to have them powered all the time nor did I want to install a toggle switch. So I did some research and grabbed my multimeter. I was searching for a wire that was live only when the other dash lights came on. After a little playing I found one and as a bonus it also ties to the dimmer, so when the dash dimmer is turned the LEDs adjust as well.
I know, I know... Pictures and description! Since for the life of me I can't figure out how to insert a picture, so I'll attach them and give a description.
Pic 1: Before
Pic 2 & 3: After Removing the bezel and the cup holder piece I found a dead harness (it must be for a feature I don't have, it was just sitting in a recess). I found the 3rd wire (Orange & White) to suit my needs.
Pic 4 & 5: Picked a spot and drilled a couple of hole. There is a flat spot on the cup holder support plate that has an angle which will allow the light to shine down. Be careful here, I did some measuring and still almost fit a strength rib on the back. I put a dab of clear silicone to make sure they stay in place.
Pic 6: Since I didn't have a crimp coupling I decided to just strip the Orange and White wire and wrap the two LED Black and White wires around the Orange and White and tape it up good.
Pic 7: I did have some ground clips so I put both solid black wires from the LEDs into one clip and found a handy existing ground.
I tested it all again beforeIi reassembled the dash.
Pic 8 & 9: All put back together and turned it on!
Can't wait to see how it looks in the dead of the night.
Old 05-02-2011, 11:01 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Sweet little mod! I like it!
Dillon-aka, The Little Kid
Old 05-02-2011, 11:08 PM
Rep:79
I posted it to fast, got button happy. I went back and edited it to finish it out.
Old 05-03-2011, 01:22 AM
crazybrazee crazybrazee is offline
Vehicle: 2007 Doadge Ram 1500
crazybrazee is on a distinguished road
What size of LED did you use on this mod. Looks super clean and almost stock. I like it a lot and have been trying to think of a way to light my mine up and now I have found it.
Old 05-03-2011, 08:49 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
It looks good!
If I may make one suggestion. You might want to look into painting the top side of each LED, as I think you'll find that it's a bit bright, shining up into your face while driving at night. I had to do this when I made a similar mod in my PT, I just used a little bit of touch up paint that I had lying around from an old vehicle (I think it was Silver)
Exco
Bill
Old 05-03-2011, 08:37 PM
Rep:79
Not really sure what size the lights are, I used a 3/16 bit though. Be careful, I had to ream the hole out a little, one side I got just right, the other I opened it up a little to much, hence the reason for a dab of silicone on the back side. I picked up a 4 pack of lights from Advance Auto Parts, about $10.00. Alpena Hyper LED was the brand.
Old 05-03-2011, 08:42 PM
Rep:79
Originally Posted by Excoastie View Post
It looks good!
Exco
Your absolutely correct. I put them at a nice down angle that they don't shine up so much, but on the way into work this morning I notice two strange white lights in my rearview mirror. Apparently it is a reflection off my back window. So I just finished coating them a little. I choose black because thats what I had on hand and it matches that part of my interior. I'll let you know tomorrow if it got rid of the mirror shine.
Old 05-03-2011, 09:17 PM
jc4041's Avatar
jc4041 jc4041 is offline
Vehicle: 2009 QC 4wd
Rep:146
jc4041 will become famous soon enoughjc4041 will become famous soon enough
ohh I like that....looks a lot better than the stupid 6 inch blue one I got from walmart that I have shoved above it in the wire harness lol
very very clean install...do the cup holders still fold up ok?
Ram DSP, CAI, Cherry Bomb Extreme, AirLift 1000
'07 Dodge Charger SRT8 SuperBee #579-CAI, DSP, dual Cherry Bomb Extremes
'07 GCSRT Stock
Old 05-03-2011, 09:43 PM
Rep:79
Yep, I planned for and did a visual test to see that the tray will close with the lights added. It all work fine.
Old 05-03-2011, 09:47 PM
jc4041's Avatar
Rep:146
cool beans...I was just gonna use some of the double sided 3m things, but it doesn't like to stick to the plastic very well, so wire harness it was lol
'07 GCSRT Stock
Kegger MOD DIY wermbang Dodge Ram Knowledge Base 8 09-09-2012 03:05 PM
2nd Gen LED Dash Light Replacement DIY wermbang Dodge Ram Knowledge Base 3 01-08-2012 11:25 PM
Mod update on my 2010 :) Win 2010 Dodge Ram Forum 27 11-25-2011 03:59 AM
Another Mod completed M n M 2010 Dodge Ram Forum 6 04-14-2011 11:56 PM
Keggar Mod wermbang Dodge Ram Knowledge Base 1 04-05-2011 03:16 AM
