Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 05-03-2011, 10:55 AM
ohmega07's Avatar
ohmega07 ohmega07 is offline
Vehicle: 07 Mega Cab
Trim Level: laramie
Rep:183
ohmega07 has a spectacular aura aboutohmega07 has a spectacular aura about
Default just gauge lights and dome lights
i am not sure why, but my gauge illumination lights and dome lights arent working, but the rest of my lights are fine, gear shift lights work, seatbelt light ect. rear dvd works ect.
any ideas on why just those 2 specifics would go out?
"If I was worried about gas mileage, I would have bought a Kia"
Old 05-03-2011, 11:42 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Any chance you have the dash dimmer knob turned all the way down....to the click?
brad
Interested in one of my mods?
Old 05-04-2011, 12:21 PM
ohmega07's Avatar
Trim Level: laramie
Rep:183
no, i use the dash dimmer sometimes, but i have checked that and its definately out, even when its dimmed to its lowest, it still illuminates the dials a fraction of a bit, but they are completely out.
Old 05-05-2011, 01:05 AM
brad12kx's Avatar
Rep:2581
This is really pointing in the direction of a bad instrument cluster. It's actually a complete computer that operates a number of things, and has the drivers for both the dome lights and dash lights. It also has the drivers for a number of other things (like almost every interior light). I am not 100% sure, but I believe the dealer can hook into the system and run diagnostics on the cluster to determine whether or not it's failing.
BUT - before you spend a bunch of cash on diagnostics, try doing a full reset. Disconnect your battery cable for 30 minutes (over night is even better). When you re-connect it, all the computers in the truck will reset. Like your home computer, sometimes issue can be resolved by rebooting.
Bad part of a reset.....the clock will be wrong, and your radio presets will be gone....along with your memory seat positions, etc. Truck might run a little weird for 5-10 minutes while the engine computer learns the sensor input. If you do this, a short highway run (10miles) is a good thing.
brad
Old 05-05-2011, 12:45 PM
ohmega07's Avatar
Trim Level: laramie
Rep:183
thanks, ended up switching a couple fuses even though they looked fine first time i checked em and then i did a reset and one or both worked and fixed the problem,
thanks guys
Have you seen this one? Dome lights..... Quiet Lunatic Electrical 5 03-08-2011 07:54 PM
Dome Lights Silvereagle Custom Dodge Ram Interior and Exterior Lighting 2 12-12-2010 01:13 AM
Interior LED Dome / Map Lights CustomShirts Custom Dodge Ram Interior and Exterior Lighting 19 08-24-2010 01:49 AM
LED Dome Lights/LED Brake Lights ShanghaiPaddles Custom Dodge Ram Interior and Exterior Lighting 23 05-06-2010 12:01 AM
95 Ram 1500 Laramie SLT Dome Lights Not Coming On? jacob tamblin Electrical 4 04-07-2010 11:56 AM
