MOPAR DECALS
Old 05-03-2011, 02:01 PM
moparkido's Avatar
moparkido moparkido is offline
Vehicle: 2009 ram 1500
Color: Gray
Rep:63
moparkido will become famous soon enough
Default Tire question
Hey guys i am new to this forum. I have a 09 ram 1500 4x4 and wanted to know if i could fit 33s without a leveling kit?
09 ram 4.7 stock for now
Old 05-03-2011, 02:24 PM
PEvil's Avatar
PEvil PEvil is offline
Vehicle: 2007 Dodge Ram 1500
Color: Electric Blue
Rep:41
PEvil is on a distinguished road
Welcome to the forum! You shouldn't have a problem with 33's as long as you do not go too wide. Going any wider than a 305 will almost always require some form of wheel spacer or aftermarket wheels with a different off-set. If you have factory 20" wheels the stock tires measure around 33".
--Superchips 3865 with Advanced Transmission Tuning--K&N Drop-In Filter--Cat-back Exhaust--Sonnax Line Booster--Bilstein 5100 Leveling Shocks--Firestone RideRite Air Springs--AirLift Load Controller II--305/55/20 Nitto Trail Grapplers--
Old 05-03-2011, 03:26 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
what Evil said. the 275/60-20s are basically 33' tires so you should be ok. The width and wheel offset are the only other factors I can think of.
Old 05-03-2011, 03:29 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Like it was said a 33x12.5 is a pretty wide tire to use on a stock wheel. A better idea would be to look into something like a 285 metric tire. A 285 is about an inch narrower then the 12.5 and half inch on the 305.
Old 05-03-2011, 03:42 PM
moparkido's Avatar
Color: Gray
Rep:63
Ya I was going to do rims and tires. The rims are offset rims that I'm looking at. I wanted to make sure they will clear. Thanks for all of yalls help
24" tire question Lakelandhuskers Dodge Ram Wheels And Tires 3 02-02-2011 12:45 AM
Newbie with tire question calbear Dodge Ram Wheels And Tires 8 01-15-2011 02:03 AM
Tire Pressure Sensor Question AKRAM Dodge Ram Wheels And Tires 3 11-21-2010 09:46 PM
Tire Question... rob Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 12-12-2009 10:53 PM
Low tire pressure indicator question imnxnyr LD RAM - General Discussion 14 10-06-2009 10:49 PM
