Old 05-03-2011, 10:12 PM
Schroeter Schroeter is offline
Vehicle: 2009 Dodge Ram
Rep:12
Schroeter is on a distinguished road
Default Swapping 4.7 for a diesel
I have wanted a diesel truck since I got my drivers license. I ended up buying a gas truck because I couldn't afford to get a diesel.
Over the past few days I have been researching waste veg oil for fuel, and browsing other sites looking for people that had swapped the motor in a newer truck. Basically I haven't found anyone that has swapped a 4.7 gas motor for a diesel, or anyone that has done this in a 'modern' truck.
I 've seen older trucks, 1980-2000 range, that were swapped with a 4BT Cummins motor. I'm trying to figure out the costs involved with this.
My truck is a 2009 Ram, 2wd auto, 4.7 engine. Is it possible to put a small diesel in this truck? (4BT Cummins being the one I'm mainly interested in)
With older trucks you don't have the problems such as computers, wiring harnesses, handful of sensors on everything, emissions, etc.
ANYONE with any information please help me out, it would be greatly appreciated.
Old 05-03-2011, 10:30 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Havent seen it done on a ram but my buddy has one in a CJ5 jeep.
Your looking at alot of work and custom fabrication.
He pulled his out of a old frito lays truck so he managed to snag some of the electronics that went with it.
Old 05-03-2011, 10:35 PM
Rep:12
The more research I do, the harder this looks.
I may just try and find an older diesel with low miles and see if I can trade my truck for it.
The whole purpose of this is to run my truck on waste vegetable oil [aka. almost free diesel] because both diesel and gasoline are over $4.00/gal here.
Old 05-03-2011, 10:39 PM
jc4041's Avatar
jc4041 jc4041 is offline
Vehicle: 2009 QC 4wd
Rep:146
jc4041 will become famous soon enoughjc4041 will become famous soon enough
you might want to double check...but unless you're sticking to offroad use only....you won't be able to register a 1500 with a diesel....since 1500's aren't offered with a diesel (yet....come on Cummins and Dodge for 2013!!)
buddy at work was thinking about doing it in his '99....and I put a lot of thought into it for my '09 as well....just something you might want to research a little more
Ram DSP, CAI, Cherry Bomb Extreme, AirLift 1000
'07 Dodge Charger SRT8 SuperBee #579-CAI, DSP, dual Cherry Bomb Extremes
'07 GCSRT Stock
Old 05-03-2011, 10:40 PM
jc4041's Avatar
Rep:146
although there is a guy on here doing a custom 6.7 drag 1500.....
'07 GCSRT Stock
Old 05-03-2011, 10:42 PM
Rep:12
Never considered registration... hmm, that's a game changer
Old 05-03-2011, 10:43 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
anything can be done with enough cash but honestly your looking at a lot of cash i would just trade in the truck
Old 05-03-2011, 10:44 PM
Color: Mineral Gray
Rep:177
My girlfriend and her dad used to use a vegetable oil/diesel blend a little over two years ago.
Honestly not worth the trouble. It has probably cost them more in the long run then it did save them (7 injectors and several fuel filters among other things)
Plus they could only run it if temps were above 50*f. I got a call one day if I had anytricks to get them started since the ratio was to lean towards the vegetable oil. After sitting for awhile plugged in with torpedo heaters pointed at the block it finally decided to fire (as the tow truck was pulling in the driveway)
You would need specialty plates/registration for a 1500 with a diesel
Old 05-03-2011, 10:52 PM
Rep:12
The temperature isn't an issue, the system I would be using uses two tanks. One is for diesel, the other for WVO. The truck starts on diesel and after it's warmed up, switches to WVO. The WVO is heated by coolant lines that come from the engine and back to the tank, the same way that your cab heater works. Basically after your engine is hot, the oil is hot.
The injectors was probably caused by improper preparation. The fuel should be filtered with a 2-micron or better filter for best results.
EDIT: That Jeep makes me drool
Old 05-03-2011, 10:54 PM
Rep:12
What would my 4.7 motor and 5 speed auto transmission be worth?
Just hit 40,000 miles, has had full synthetic Valvoline oil since day 1, K&N oil filters, Seafoam and Lucas Oil fuel treatments every other oil change.
2010 6.7 Cummins Diesel Slow Sluggish Acceleration ehillman Cummins Diesel Specific Topics 22 07-29-2015 09:25 AM
NHRDA Northwest Diesel Nationals, Spokane Washington NHRDA Drag Racing Discussion 1 05-12-2011 08:00 PM
3rd Annual Jefferson State Diesel Nationals, Redding CA May 14th NHRDA Drag Racing Discussion 2 05-12-2011 12:03 AM
Diesel Tunes Performance Chip knsram Dodge Ram General Discussion 5 02-04-2011 11:08 AM
1992 Dodge Ram w/ Cummins diesel Tranny options? Russ Bellinis Cummins Diesel Specific Topics 2 06-11-2009 02:55 PM
