Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
ZDOG
Old 05-03-2011, 10:12 PM
westbygodtbone westbygodtbone is offline
Vehicle: 2001 Dodge Ram
westbygodtbone is on a distinguished road
Default 2001 Dodge Ram Air Conditioning
My heater core went out this past winter so I had to replace it. When I checked everything after changing it, both the air conditioning and heater worked as advertised. But it was cold out.
However, now that the weather is getting warmer, my air conditioner does not blow cold air. It's as though the heater is constantly on when the air conditioning is turned on, no matter what the temperature or controls are set at. It always blows HOT air. It does not get any cooler even when the temp controller is turned down. I replaced the A/C control on the console and that didn't help.
I serviced the refridgerant and the condensor and lines get cold, but still........no cold air coming through the vents.
I checked fuses and I can hear the compressor clutch kick on and off.
Could it be possible that I did not reconnect something (connector/wiring) when I put everything back together under the dash? Any suggestions? Thanks ahead for any help I may get.
Tony
Old 05-03-2011, 10:18 PM
Dalton's Avatar
Dalton Dalton is offline
Vehicle: 2005 Dodge Ram Daytona
Trim Level: Daytona
Rep:43
Dalton is on a distinguished road
Did you replace the core yourself? Sounds to me like one of the little doors that switch between heat and air inside the air plenum were knocked off track.
2001 dodge ram, air conditioning, not working
2009 TSBs BlueJet 2009 Dodge Ram Forum 38 10-28-2014 05:03 PM
2001 Dodge Ram Loping in Overdrive stealtharsenal 5.9L V8 Specific Topics 6 04-10-2011 06:50 PM
2001 Dodge Ram 1500 5.2L Cat Problem Quiet Lunatic North East 3 05-18-2010 11:22 PM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
2001 Dodge 3500 diesel problems zmantopdog Cummins Diesel Specific Topics 2 08-23-2009 11:42 PM
