Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 05-04-2011, 07:57 PM
Saugie53 Saugie53 is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: Hemi Sport
Saugie53 is on a distinguished road
Default Question With Ball Joint Press
I'm going to be doing my ball joints on friday and I just got my ball joint press. In the dodge ram manual it says you should use extreme pressure lubricant on the threads of the press, what kind of lube should I use just regular extreme pressure grease like the kind you would use to grease the actual ball joints or is there some other kind of lube I should use??
Old 05-05-2011, 12:53 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Regular ball joint grease.
Old 05-05-2011, 04:07 PM
great thanks!!!
question on Ball Joints JLash87 Suspension 9 02-15-2011 12:02 AM
Lower ball joint falling out 98 ram1500 blodge5.2 Suspension 1 10-06-2010 07:47 AM
do ball joint make a cracking sound??? goatmilk2878 Drive Line 1 06-19-2010 09:13 AM
Lower ball joint issues bruno9 Newbie Checkin! 10 02-13-2010 01:10 AM
Squeaky Ball Joint? 04RAMsprt Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 01-21-2010 05:35 PM
