Old 05-04-2011, 08:23 PM
rolledxj rolledxj is offline
Vehicle: 2011 ram 1500
Trim Level: SLT Outdoorsman
Color: Deepwater Blue
rolledxj is on a distinguished road
Default Resonator Removal
Has anyone with single exhaust removed their resonator? I have a 2011 Outdoorsman with a Hemi, but would like to hear the motor a little, instead of just seeing the tach climb. My concern is that it might sound strange when it goes into 4 cylinder mode. Do the factory duals sound like garbage when MDS kicks in? As much as I would have liked to have the factory duals, this Outdoorsman had everything else I was looking for and more.
Old 05-04-2011, 10:01 PM
I'd go the other direction...swap out the stock muffler for an aftermarket one and leave the resonator on.
You are correct in assuming it will sound really bad without a resonator when it slips into MDS mode.
Old 05-04-2011, 10:31 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
'Dog said it best,,,, Change the muff, leave the res,,,
Old 05-05-2011, 01:37 AM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
My friend removed the exhaust from before the muffler back so it's dumped under the cab on his and it sounds good even when mds kicks in
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 05-07-2011, 11:19 AM
Canuk1500's Avatar
Canuk1500 Canuk1500 is offline
Vehicle: 2011 Outdoorsman
Trim Level: Slt/outdoorsman
Color: deep water blue
Canuk1500 is on a distinguished road
I had the muffler changed to a Dynomax and left the resonator alone on my '09 slt hemi. Sounds way better than the stock, not to much louder and sounds a whole lot better, it was a direct swap no piping had to be changed. Nice thing is the pipe is 3" so it flows good already. I will go this route again for my next truck. MDS cuts in it does get and different tone for sure deeper and weaker sound. good thing I have the 3:55's so it doesn't go to MDS to often!
Debadge, cabin air filter, side steps, mopar mud flaps, removed window tape, dyno max muffler, 5100 Bilsteins all corners, ion 179b, nitto terra grappler 305/55/20
