Old 05-05-2011, 01:23 AM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
Default 4th gen third brake light swap
I just got in my smoked 3rd brake light and it looks great. Really goes with the theme...
Tools needed:
phillips screwdriver, (flathead and a rag optional)
The job:
The stock brake light is just held on with two phillips head screws, but also has some silicone sealant to keep it from leaking. I took out the two screws and then used a flathead wrapped in a rag to gently pry up on each side to break the seal. You will find three bulbs all run into one wiring harness. Pull that wiring harness off the plastic holder to give you enough slack to undo the bulbs. Take them out and twist into the new light. I didn't use any sealant, but I may go back and add some later. Took me longer to get to mine thru the back window than it did to swap the lights. I ordered my light from ebay from smoked_lights. He did a great job and the cost was really reasonable.
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
Old 05-05-2011, 01:42 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
So where's the finished product? Is in in the photo that didn't load?
Old 05-05-2011, 01:53 AM
E.L.D. 44's Avatar
Rep:388
There shouild be three photos. First, before shot. Second, the two brake lights side by side. Third, finished product. Are they not loading?
MY MOD THREAD
Old 05-05-2011, 06:27 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
They loaded for me. Looks really good man!
Old 05-05-2011, 12:59 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
lookin good bud...reps for that
Old 05-05-2011, 01:05 PM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Are the cargo lights on the bottom of the light now instead of in the middle?
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 05-05-2011, 01:13 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Smile
Looks fantastic on your white RAM Is that a Recon or different manfacturer ? I put the Recom on mine and love it. I did not put any extra sealent as well and so far no leaks. Great mod, reps to ya........
Old 05-05-2011, 01:51 PM
E.L.D. 44's Avatar
Rep:388
I'm not sure I'm following what you are asking. The cargo lights and brake light are all mounted straight across the light...
I couldn't see spending the money on a recon and then smoking it so I went with an OEM smoked one. Got it for 30 bucks cheaper than a recon. I may go back and add sealant later, but with the foam around it I'm not real concerned about it leaking...
MY MOD THREAD
Old 05-05-2011, 03:11 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Lookin good man! Really adds to the truck!
Dillon-aka, The Little Kid
Old 05-11-2011, 11:58 PM
TxPride911 TxPride911 is offline
Rep:27
TxPride911 is on a distinguished road
Looks great. Seems like your truck was manufactured from the factory better than mine! My light bulb went out on my 3rd brake light and the dealership had to first off break the light in order to get it off because it was sealed because of a problem they had with those years and water leaking through the light into the headliner. After having my truck there all day and them replacing it I took it through a car wash and of course now water is coming through my headliner on the inside of my truck. Pretty furious to say the least.
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 09:19 PM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 03:43 PM
Trailer Brake Light Problem ronanderson57 Electrical 5 04-20-2011 04:25 AM
abs light, brake light, speedo not working, stalls when stopping B and B LANDSCAPES Electrical 21 04-07-2011 10:56 PM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 03:33 PM
