Old 05-24-2011, 09:16 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I'm guessing it's like someone else posted, a bushing is tweaked from jacking it up so high, I'd loosed all the bushing in the rear and retorque them. Next thing I'd try is the springs rubbing where they are seated...good luck. Otherwise, any other opinions on the kit? Would you in fact do it again?
Sean
Old 05-24-2011, 09:41 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
yeah I'd prob still buy it again. I'm just getting irritated with this sound I can't locate. I'm sure I'd write a more exciting review if it wasn't driving me nuts.
I'm going to get someone else to look. A fresh set of eyes might catch what I'm missing. I might break the torq and retorq the control arms but it looks like a real pain in the but. The rear bolts of all 4 arms are kind of hard to get to where I would be able to put 225 ft-lbs on them. there's just no consistancy to the noise.
Old 05-24-2011, 09:46 PM
snrusnak's Avatar
Rep:1385
Have you tried contacting otto-max, maybe tell them this happened right after the install...and get their tech guys working on it, and theyll come up with the answer?
Sean
Old 05-24-2011, 10:09 PM
CHVYKLR's Avatar
Rep:252
Another "to do" for tomorrow. I started to the other day from work but it was too early in the morning. Called SDtrucksprings and they couldn't help. Ottomax is West coast and after a couple hours at work I just plain forgot. See what I mean...I'm so focused that I'm forgetting the logical things first.
Old 05-24-2011, 10:12 PM
snrusnak's Avatar
Rep:1385
lol, you'll get it figured out, they seemed like good people when I talked with them. Then after you do get it figured out, we all can learn from you're experience, isn't it fun being the guinea pig!? lol
Sean
Old 05-25-2011, 07:28 PM
CHVYKLR's Avatar
Rep:252
went back to the stock shocks and problem solved!! I've been in contact with Randy and I'm trying to get as much info as I can collect for him so we can figure this out. His Dodge contact told him the crewcab trucks ALL have the same rear spings but when I pulled my stock springs they have different part numbers (driver vs passenger side). So I would like to see how much the 2wd and 4wd vary with regards to ride height. He said they measured the 4wds at 39". I told him when I started mine sat at 38" to 38 1/4".
can you guys help me out? if you could measure from the ground up the wheel center to the bottom of your wheel-well and state year and if you are 2wd or 4wd.
example:
my truck is a 2wd, 2009, 20" wheels and measures 37" driver side and 37 3/8" passenger side now with the Otto-max springs.
I took some pics for him and collected all the part numbers I could. So lastly, I like to give him some 2wd vs 4wd ride stock ride height data. Thanks!
Old 05-25-2011, 07:34 PM
snrusnak's Avatar
Rep:1385
hmmm glad you found your answer, do you know specifically what it is with the shocks though? or is that what he's looking into? I can't verify right now but will tomorrow evening(I have my truck loaded down right now)....but going from memory I want to say I measured the driver rear at 38 to 38 1/8, and driver front at 35....will verify tomorrow. I am quad cab, aftermarket tires, but stock size(265 70 17).
Sean
Old 05-25-2011, 09:07 PM
CHVYKLR's Avatar
Rep:252
Randy told me that I might have to "shim" the shocks. well the kit shocks aren't the same width as the stockers at the eyelets. I tried using a washer on each side but there was still maybe a 1/16" or so gap. Torq'ing the bolts down wouldn't squeeze the gap closed. Installing them I never thought that the little space would cause such a problem.
Old 05-25-2011, 10:11 PM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
u need to put multiple washers and make sure to lube up the bushings real good. i'm glad you didn't fight through all those link arm bolts to find out that wasn't it.
Too many mods to fit here!
Old 05-25-2011, 10:29 PM
CHVYKLR's Avatar
Rep:252
I'm just going to run the stock shocks since I only ended up with 1" drop. The kit shocks measured 2 3/4" shorter than the stock shocks too...would've been pretty good with a 2" drop. Randy said all the testing was done on a 4wd and the kit dropped it down drom 39" to 37". Maybe the 2wds sit lower. Like I said Randy didn't think so b/c his Dodgle contact told him all crewcab rear coils were the same.
either way I'll sleep good tonight now that I know it's not squeeking
leveling by rear drop.. sku2erz Suspension 12 03-24-2015 05:08 AM
Leveling Kit: Lift front or drop rear? Trucks n Guns Dodge Ram Forum Polls! 9 07-17-2014 03:49 PM
leveling by lowering the rear???? deep blue Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 6 04-22-2010 04:54 PM
2010 leveling by dropping the rear 1 inche. StoneyWV Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 03-27-2010 09:30 PM
Leveling rear of 2009 Ram CC 4x2 Marine671 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 0 09-17-2009 11:12 PM
