Old 05-05-2011, 07:19 PM
BrentCRX BrentCRX is offline
Vehicle: 2010 Ram
BrentCRX is on a distinguished road
Default What is the proper way for HID.
I am having a struggle with my truck.
What is the proper to wire HIDs with out upsetting the
ever annoying TIPMCGW system
I am about ready to sell a truck I other wise like very much.
Factory bulbs have issues HIDs have issues my new HID kit has issues.
Please help.
Old 05-05-2011, 07:47 PM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
Please help.
Can you provide more information? What "issues" are you having? And what is a TIPMCGW system?
The only problem I ever had with HID's in my truck was the location of the ballasts for the fog lights... they would cause interference with the pressure sensors in the tires. After some experimentation (moving the ballasts around) I found a spot that worked.
No problems at all with the headlight ballasts.
Old 05-05-2011, 08:39 PM
Stonednloaded Stonednloaded is offline
Rep:14
Stonednloaded is on a distinguished road
I just ordered a kit 6000K from ddm tuning only lows and fog because hi beams are drls if you have quad headlamp and live in canada anyways i just used a relay harness for my lows and everything else was best kind
Old 05-06-2011, 01:28 AM
Vehicle: 2010 Ram
Flickering problems, tpms problems. Worried the ECM is resetting the circuit causing the problem
Old 05-06-2011, 08:00 AM
Upstater's Avatar
Trim Level: Bighorn
Color: Stone White
Rep:132
The flickering is easily resolved by using in-line capacitors; from what I understand they are almost a necessity. Like I said, the only time I had TPMS problems was with the ballast locations for the fogs - try moving them around. When my HID's kick on I still get the TPMS light on the dashboard for a brief instant but it goes out, and I checked the PCM with my programmer and it's not throwing codes...
Common problems with HID's but easily solveable! Good luck!
Old 05-18-2011, 10:01 PM
Gregn86's Avatar
Gregn86 Gregn86 is offline
Vehicle: 2009 Dodge Ram
Color: Gray
Gregn86 is on a distinguished road
Upstarter, where did you end up mounting your fog light ballast because im having the problem of the TPMS staying on. Im also having the flickering and one headlight staying on problem i will try an inline capacitor for that. but another problem is after about 5 minutes of having my fog lights on the left one will turn off and the right one stays on. any ideas on that?
Old 05-19-2011, 07:16 AM
Upstater's Avatar
Trim Level: Bighorn
Color: Stone White
Rep:132
I ended up removing my fogs because I couldn't find a location for the ballasts where they didn't mess with the TPMS. If you want to keep them, you just need to experiment with locations, or someone else suggested wrapping them in aluminum foil to try to cut down on the interference.
I really think all your other problems can be traced back to not having flicker cancelers. Install the capacitors and if you haven't damaged a ballast with all the flickering you should be all set.
Proper way to break in new truck earlzie 2011 Dodge Ram Forum 37 12-28-2011 01:39 AM
Proper PSI on Aftermarket wheels BCWhite Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 12 03-06-2011 01:43 PM
proper break in mileage wascobi 2010 Dodge Ram Forum 21 10-02-2010 10:45 PM
Proper oil weight for MDS ? drp6982 Oil Change 4 05-31-2010 09:00 PM
Proper Gearing and Highway RPM for 5.7 StoneyWV 2010 Dodge Ram Forum 1 02-14-2010 01:38 AM
