Old 05-05-2011, 09:34 PM
snojet snojet is offline
Vehicle: 2010 1500 Hemi
Trim Level: trx 4
snojet is on a distinguished road
Default Leveling kit
What's the deal with the kits? Do they screw up the front end or don't they? The more I read into this topic the more questions I have . Some say there great and some say the through the front end out of wack. Waht's the deal???????????????
Old 05-05-2011, 10:45 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
What kind of kit are you looking at?
Old 05-06-2011, 01:23 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Some people will tell you that they cause front end problems. Stressed ball joints is one big one. Not saying that it doesnt happen but it is a rare occasion to blow out ball joints from a lift kit (usually improper installation is to blame there)
With some rams your have to be careful with how high of a leveling kit you put on because of the pitch it puts your CVs on and will cause death wobble.
There are plenty of different kits to choose from and most likely there is someone around here that has experience with it and can answer questions for you.
Old 05-06-2011, 01:23 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
I used the Daystar 2" front 1" rear lift/leveling kit and have not had any issues on my 2010 1500 4x4. I installed it myself and had it professionally aligned after. Others hate Daystar, to each their own, works great for me.
Spyntec Hubs, 35" Cooper STT, Synergy Steering Brace, out of money........................
Old 05-06-2011, 01:40 PM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
What he said. I put a leveling kit in my '07 Ram and while I never had death wobble I had a very noticeable vibration in the driveline when in 4WD. The angle of the CV joints was so severe the lift tore them up in less than 6 months.
People associate "death wobble" with driveline vibrations quite a bit, but I believe that's a misapplication. True death wobble is most common in short wheel-based vehicles like Jeeps (I have one) with excessive lifts; it's actually a result of the geometry of the steering components being out of whack... "Death wobble" occurs when the vehicle hits something relatively small (bump in the road, etc.) that a correctly aligned steering system wouldn't sneeze at... but with the wobble instead of the suspension and steering absorbing the disturbance it sets off sort of a "chain reaction" in the steering components that amplifies that little bump until it becomes an uncontrollable STEERING wobble that will run off the road or into opposing traffic unless you come to almost a complete stop.
Old 05-06-2011, 08:39 PM
Redcomet0079's Avatar
Redcomet0079 Redcomet0079 is offline
Vehicle: 2011 Ram 1500
Trim Level: Outdoorsman
Color: Bright White Two tone
Rep:15
Redcomet0079 is on a distinguished road
I have/had the same question as snojet. I have yet to take delivery on my '11 outdoorsman, and was thinking about getting it leveled(they look better in my opinion(what it's worth! lol)). From reading on here and other places. I think I've read the majority of issues come up with a 2.5" and above leveling kit. 1.5"-2" really aren't having the issues. Am I correct in this? Please correct me if I'm wrong, I'm new to the forum and new to this subject.
Old 05-07-2011, 09:29 AM
old hot rod's Avatar
old hot rod old hot rod is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Rep:386
old hot rod is just really niceold hot rod is just really niceold hot rod is just really niceold hot rod is just really nice
Send a message via Yahoo to old hot rod
Not sure about people having trouble, I went with Hell Bent Steel 2 1/5in. and then had it lined up, and ZERO trouble drives just like stock, rides like stock, but looks alot better than stock!!!!!!!!!!!!!!!
Hope this helps!!
Hell Bent Steel Leveling kit, K & N filter, Tinted Windows,
Mufflex DOD18M, Mopar Intergrated Trailer Brake,
DiabloSport Predator (U7137) 180 Thermostat, WeatherTech Vent Visors
DiabloSport Catch Can (C-1040)
Old 05-07-2011, 12:15 PM
Color: Mineral Gray
Rep:177
From what I've seen/experienced 2.5" isn't a problem but anything above that is. When you get to 3" plus there are other steering components needed other then just a spacer.
Old 05-07-2011, 08:27 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
I think with the 4th GEN ram 1500 4x4's the cv joint's on the front half-shafts are border line on any angle increase from level period. I believe it was not intentional, it just happended when they designed the front ends. I think if you install any type of leveling kit that increases this angle, it's either gonna vibrate or it's not from binding in the cv joint, I think it is just that close, so if you have levelled the front of your truck and it doesn't vibrate in 4WD mode you are lucky. If this was a non-issue with these trucks, I would have levelled my truck a long time ago. I have decided not to dick with it........factory rake, oh well. Still has an awesome stance.
Old 05-08-2011, 10:07 AM
Rep:15
Hmmm. What a conundrum. Some do, some don't. I'm not sure what to do. They just look so much better with. Although from what I've seen, the Outdoorsman doesn't seem to have as great of a rake as others. Course, that could just be camera angle.
Any tips/advice for installing a front end leveling kit? RamboObmar 2011 Dodge Ram Forum 16 03-25-2011 04:07 PM
Leveling kit on a 2WD? thumper36 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 11-27-2010 05:22 PM
2WD Leveling Question bigedschukar Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 20 11-18-2010 08:20 PM
Quoted $1373.50 for alignment after Installing Leveling Kit doozy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 11-01-2010 10:20 PM
Leveling Kit miller2013 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 23 04-29-2010 10:10 AM
